Home » Eclipse Projects » Test and Performance Tools Platform (TPTP) » AGR 4.3 -> AGR 4.4
AGR 4.3 -> AGR 4.4 [message #108461] Fri, 10 August 2007 16:00 Go to next message
Eclipse User
Originally posted by: joel_patterson.verizon.net
I recorded a number of AGR tests in TPTP 4.3 under Eclipse 3.2.1.
Will they run in TPTP/AGR 4.4 with Eclipse 3.3 -- I brought up the
workspace there and it's acting odd -- I see the list of tests, but not
the tests themselves.
Re: AGR 4.3 -> AGR 4.4 [message #108585 is a reply to message #108461] Sun, 12 August 2007 08:41 Go to previous messageGo to next message
Paul Slauenwhite is currently offline Paul Slauenwhite
Hi Joel,
Yes, AGR tests recorded in TPTP 4.3 will run in TPTP 4.4 (e.g. backward
compatible). What do you mean, 'I see the list of tests, but not the tests
themselves'? Are you referring to the test navigator?
Paul
"Joel Patterson" <joel_patterson@verizon.net> wrote in message
news:f9ig40$sjf$1@build.eclipse.org...
> I recorded a number of AGR tests in TPTP 4.3 under Eclipse 3.2.1. Will
> they run in TPTP/AGR 4.4 with Eclipse 3.3 -- I brought up the workspace
> there and it's acting odd -- I see the list of tests, but not the tests
> themselves.
Re: AGR 4.3 -> AGR 4.4 [message #108837 is a reply to message #108585] Mon, 13 August 2007 11:24 Go to previous messageGo to next message
Eclipse User
Hi Paul,
I recorded tests under 3.2.1 and TPTP 4.3 with AGR.
I then downloaded TPTP 4.4 with AGR and opened the same workspace.
The TestCases tab comes up and I see the list of tests, but I can't
select anything, see the recorded tests or do a playback.
Paul Slauenwhite wrote:
> Hi Joel,
> Paul
>> themselves.
Re: AGR 4.3 -> AGR 4.4 (Fixed) [message #108876 is a reply to message #108837] Mon, 13 August 2007 13:09 Go to previous message
Eclipse User
Nevermind! Fixed it.
Joel Patterson wrote:
> Hi Paul,
>> Hi Joel,
>> backward compatible). What do you mean, 'I see the list of tests, but
>> not the tests themselves'? Are you referring to the test navigator?
>> Paul
>>> Hi,
>>> not the tests themselves.
Previous Topic:[AGR] Unsuccessful recording on Linux
Next Topic:Missing "Collect object references"
Current Time: Sat May 25 09:36:20 EDT 2013
Powered by FUDForum. Page generated in 0.02197 seconds
