Home » Eclipse Projects » Jubula » add own parameter types
add own parameter types [message #1063607] Thu, 13 June 2013 13:48 Go to next message
khalil alrifai is currently offline khalil alrifaiFriend
hello,
i have extended jubula for testing an RCP application. i want to create a test case with a parameter type of map or list
how can i use another test case parameter type such as "java.util.Map"
example:
<toolkitComponent type="de.kupzog.ktable.KTable" visible="true">
<realizes>guidancer.abstract.Widget</realizes>
<testerClass>org.eclipse.jubula.rc.common.tester.KTableTester</testerClass>
<componentClass name="de.kupzog.ktable.KTable" />
<action name="selectElements" changed="1.0">
<method>selectElements</method>
<param name="elements">
<type>java.util.List</type>
</param>
</action>
</toolkitComponent>
best regards
Re: add own parameter types [message #1065055 is a reply to message #1063607] Mon, 24 June 2013 07:52 Go to previous message
Alexandra Schladebeck is currently offline Alexandra SchladebeckFriend
The best place to ask this might be the developer list.
Alex
Previous Topic:Keyboard Layout
Next Topic:Cleaning Testresults takes very long time
Current Time: Sat Jul 22 09:03:42 GMT 2017
Powered by FUDForum. Page generated in 0.06023 seconds
