Home » Modeling » EMF » EMF's Jet templates costumization(ClassCast Exception when I add new templates to common ones)
EMF's Jet templates costumization [message #1060683] Mon, 27 May 2013 14:36
Amine BEN is currently offline Amine BEN
Hi all,
I'm trying to costumize the EMF API generation of model code by adding a new file.
I created a new project where I copied the templates from *.codegen.ecore preserving the folder's hierarchy, then I changed the templates directory in the genmodel options to the one I just copied. In order to make sure that the generation process uses these templates I added some java comments to the templates. This worked just fine.
When adding a new jet template to the template's folder, and running the generation, a java class for this template is not generated in the JETemitter project.
How can I solve this problem
Thank you in advance
Previous Topic:Once again Factory not found: org.eclipse.emf.cdo.server.queryHandlerFactories[ocl]
Next Topic:Run generated Editors in Eclipse4 RCP
Current Time: Tue May 28 03:52:36 EDT 2013
Powered by FUDForum. Page generated in 0.01524 seconds
