| Re: many attributes Source en one target attribute [message #1060634 is a reply to message #1060526] |
Mon, 27 May 2013 08:18   |
Hugo Bruneliere Messages: 469 Registered: July 2009 |
I guess you want to concatenate the value of several attributes into a single String value (to set another attribute).
To this intent, you can use the different available operations on String.
Note that Integer, Real and Boolean values can be converted to String by using the toString() operation.
Hugo Bruneliere - R&D Engineer
AtlanMod research team (Inria, EMN & LINA)
Ecole des Mines de Nantes
Nantes - France
FUDForum. Page generated in 0.02275 seconds
