Home » Modeling » TMF (Xtext) » Scoping specific GMF elements in xtext grammar
Scoping specific GMF elements in xtext grammar [message #1060271] Thu, 23 May 2013 14:49 Go to next message
Phil H is currently offline Phil H
Member
I've a special use case and not sure if it's possible.
To clarify the initial situtation, I've attached an image:
index.php/fa/15028/0/
As you can see, it's possible to have different super classes. A super class can be extended by a constraint, which should be described by a xtext grammar. What I now want is that when I add a constraint to super class 1, only nodes A,B and C should be able to refer.
At the moment also X and Y would be scoped, cause the resource description searches the whole Resource.
I've no idea if it would be possible to acces the current used node of GMF or if there is another solution. Can anyone give a hint?
Re: Scoping specific GMF elements in xtext grammar [message #1060309 is a reply to message #1060271] Fri, 24 May 2013 02:36 Go to previous messageGo to next message
Alexander Nittka is currently offline Alexander Nittka
I cannot help you with the GMF-related part, but better practice is not to adapt the scoping but rather do validation (and code completion). Limiting the scope will result in generic "could not resolve reference"-errors (yes, you could also adapt those messages). If you implement validation, you can give the user specific error messages, like "you cannot reference X here, because...".
Think of a java assignment:
Long x=(String)y;
What would you think of the java tooling, if you were told that the type String could not be found? After all, it's there (Visibility vs validitiy).
Alex
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext@itemis.de
Re: Scoping specific GMF elements in xtext grammar [message #1060674 is a reply to message #1060309] Mon, 27 May 2013 12:11 Go to previous message
Member
You're right about the validation aspect, but then a user would see all nodes which is not what I want. A Validation can also be implemented, but what I want is a filtered list which shows the user only valid entries. But the problem here is the interaction with gmf.
Previous Topic:Update of resource description
Next Topic:Add my var in Quick Reference
Current Time: Tue May 28 17:04:49 EDT 2013
Powered by FUDForum. Page generated in 0.01496 seconds
