Home » Modeling » QVT-OML » how to use two target sources?
how to use two target sources? [message #1060613] Mon, 27 May 2013 06:24 Go to next message
Emre Taspolatoglu is currently offline Emre Taspolatoglu
Hello there!
I have a transformation where I use my own meta-model as a source. And as for the target models, I need to use two meta-models which are -indirectly- related together.
How could I achieve this? Any help will be appreciated.
Thanks.
Re: how to use two target sources? [message #1060671 is a reply to message #1060613] Mon, 27 May 2013 12:06 Go to previous message
Sergey Boyko is currently offline Sergey Boyko
Hi Emre,
Actually you do not need to do anything special in order to achieve that. Just create objects from desired metamodels. For example:
modeltype UML uses "http://www.eclipse.org/uml2/4.0.0/UML";
modeltype Ecore uses "http://www.eclipse.org/emf/2002/Ecore";
transformation NewTransformation(in src : UML, out dst : UML);
main() {
	object EClass {
		name := "ECore class"
	object Class {
		name := "UML class"
Type of transformation parameters' 'dst' (which is 'UML') is used as a hint on file extension to be used for output file. For the transformation above output file 'NewTransformation.uml' has the following content:
<xmi:XMI xmi:version="20110701" xmlns:xmi="http://www.omg.org/spec/XMI/20110701" xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" xmlns:uml="http://www.eclipse.org/uml2/4.0.0/UML">
  <ecore:EClass xmi:id="_5XiVUMbtEeKBSPmarAtVhQ" name="ECore class"/>
  <uml:Class xmi:id="_5XiVUcbtEeKBSPmarAtVhQ" name="UML class"/>
</xmi:XMI>
Sergey
Previous Topic:Stereotypes and multi-valued attributes
Current Time: Mon May 27 22:31:17 EDT 2013
Powered by FUDForum. Page generated in 0.01494 seconds
