Home » Modeling » EMF » [Texo] Generated Code
[Texo] Generated Code [message #1060620] Mon, 27 May 2013 07:15 Go to next message
Sir Wayne is currently offline Sir Wayne
i have a Problem with the Texo Code generation and References.
I create a Anntotation Model, so that all my classes have a Prefix DTO.
e.g. ecore EClass A and EClass B, will be generated as ADTO and BDTO.
That works perfectly, but the References doesn't use the "new name"...
EClass A has a Reference to B. So i would except:.
public class ADTO
        implements
        Serializable
private BDTO b;
BUT
the generated Code looks like and the class B doesn't exist.
public class ADTO
        implements
        Serializable
private B b;
Re: [Texo] Generated Code [message #1060648 is a reply to message #1060620] Mon, 27 May 2013 09:07 Go to previous messageGo to next message
Martin Taal is currently offline Martin Taal
Hi Sir Wayne,
Hmm, seems like a clear bug... can you enter a bugzilla and attach your model/annotationsmodel to it? Or if you can't
share it completely the annotation model snippet which defines the postfix.
gr. Martin
On 05/27/2013 01:15 PM, Sir Wayne wrote:
> Hello,
> public class ADTO
> implements
> Serializable
> private BDTO b;
> BUT
> public class ADTO
> implements
> Serializable
> private B b;
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [Texo] Generated Code [message #1060660 is a reply to message #1060648] Mon, 27 May 2013 10:51 Go to previous message
I created a Bug.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=409157
Previous Topic:[Teneo] org.hibernate.proxy.HibernateProxy not found when running as RCP
Next Topic:Once again Factory not found: org.eclipse.emf.cdo.server.queryHandlerFactories[ocl]
Current Time: Tue May 28 11:29:11 EDT 2013
Powered by FUDForum. Page generated in 0.01457 seconds
