Home » Modeling » EMF » [EMF] Change volatile and transient properties
[EMF] Change volatile and transient properties [message #1060651] Mon, 27 May 2013 09:31
Aleksandar Toshovski is currently offline Aleksandar Toshovski
When I store some instances of an ECore model and then change violate value, would I have an error when I try to read the file and what kind of exception will occur?
And the same question about transient. If something is transient=true and then is changed to false. If i have instancies from the old ECore model, should I expect some kind of errors? And when transient=false and gets changed to transient=true. Would the stored values be ignored, or I'll recieve an error?
Aleksandar
[Updated on: Mon, 27 May 2013 09:32]
Report message to a moderator
Previous Topic: problem with inheritance and access to subclass
Next Topic:[Teneo] org.hibernate.proxy.HibernateProxy not found when running as RCP
Current Time: Tue May 28 03:53:42 EDT 2013
Powered by FUDForum. Page generated in 0.07820 seconds
