Home » Eclipse Projects » scout » Error when using External plugin (re-lanching error )
Error when using External plugin [message #1059217] Fri, 17 May 2013 06:58 Go to next message
Yassine MILHI is currently offline Yassine MILHI
I am trying to solve a strange error.
These are the steps I followed:
I've added a plugin that contains some libraries;
then added it to the server manifest in the required plugins section.
I also added this plugin to the server product dependencies by pressing "add required plugins".
I've put this line inside start method of server Activator:
    IFuture<IExternalAccess> platform = Starter.createPlatform(null);
It is responsible for launching a platform.
(see Attachment Steps.jpg)
Here is the problem:
When I launch the server product for the first time it works perfectly (see Attachment below Launch_firstTime.jpg).
But when I re-launch the server product it doesn't work.
Error code:
Caused by: java.lang.LinkageError: loader constraint violation: loader (instance of org/eclipse/osgi/internal/baseadaptor/DefaultClassLoader) previously initiated loading for a different type with name "javax/xml/namespace/QName"
That plugin works fine in a separated stand-alone java project, even if I relaunch it many times.
This problem persists even if I delete the project, switching workspace or even rebooting the PC !
The only solution for now is to change the eclipse instance.
Yassine.
Re: Error when using External plugin [message #1059226 is a reply to message #1059217] Fri, 17 May 2013 07:58 Go to previous messageGo to next message
Jeremie Bresson is currently offline Jeremie Bresson
Yassine MILHI wrote on Fri, 17 May 2013 12:58
Are you sure that the plugin is OSGi ready?
You are not the only one, I just searched "java.lang.LinkageError: loader constraint violation" in google. You get a lot of material.
Your can read:
* http://frankkieviet.blogspot.ch/2009/03/javalanglinkageerror-loader-constraint.html
* http://chamibuddhika.wordpress.com/2012/05/15/learn-by-errors-java-osgi/
Re: Error when using External plugin [message #1060641 is a reply to message #1059226] Mon, 27 May 2013 08:48 Go to previous message
Thank you Jeremie for your response.
the problem was resolved regarding this Topic:
http://www.eclipse.org/forums/index.php/t/487723/
I think this is related to the scout architecture . It mean that we have for each external access, create a service that does the job.
regards
Yassine
Previous Topic:Logout fails
Current Time: Mon May 27 23:32:08 EDT 2013
Powered by FUDForum. Page generated in 0.05412 seconds
