Home » Eclipse Projects » EGit » http.sslcainfo config option
http.sslcainfo config option [message #1058841] Wed, 15 May 2013 07:39 Go to next message
R Shapiro is currently offline R Shapiro
Is the configuration option http.sslcainfo supposed to be working in EGit/JGit? It doesn't seem to be working for me with .pem files in EGit 3.0.0.201305112223. Command-line Git (1.8.2.1) is happy with these files.
If it's not implemented yet, is it in the queue of pending tasks?
Re: http.sslcainfo config option [message #1060195 is a reply to message #1058841] Thu, 23 May 2013 09:05 Go to previous messageGo to next message
Christian Halstrick is currently offline Christian Halstrick
Member
Currently http.sslcainfo is not supported by JGit. I have some ooold proposals [1], [2] which add client and server side support for certificate based authentication to JGit. They'll bring http.sslcainfo. Somehow I had not enough time to finish this and forgot about them. From my perspective the demand for this feature was also not so high. But I think it's time not to get this through. I'll continue to work on these two changes and propose some updated commits.
[1] https://git.eclipse.org/r/#/c/3199
[1] https://git.eclipse.org/r/#/c/3200
Ciao
Chris
Re: http.sslcainfo config option [message #1060640 is a reply to message #1060195] Mon, 27 May 2013 08:41 Go to previous message
The main utility of http.sslcainfo is for servers that for whatever reason need to use self-signed certs for https access. In this case remote operations like clone, push and fetch won't work without this feature, unless you disable verification altogether (http.sslVerify=false), which is vulnerable to man-in-the-middle attacks.
Previous Topic:JGit RevWalk.isMergedInto()
Current Time: Mon May 27 22:56:17 EDT 2013
Powered by FUDForum. Page generated in 0.01587 seconds
