Home » Newcomers » Newcomers » how to install Eclipse on Mac OSX?(installing Eclipse)
how to install Eclipse on Mac OSX? [message #646856] Sat, 01 January 2011 10:26 Go to next message
Tom Peters is currently offline Tom Peters
I try to install eclipse on my iMac. There is elaborate documentation on how to use Eclipse but I found no info on how to install it on specifically an iMac.
Also I could not find a .dmg with a proper .app .
What I could download is a tarball of Eclipse Helios JEE for Mac OSX Cocoa x86 64 bit. I would be able to unpack it in my private directories, but I rather would have it go into my normal Applications dir. That however requires su-ing to root, for which I have to break open my standard OSX install.
How am I supposed to install Eclipse?
Thanx,
Tom
Re: how to install Eclipse on Mac OSX? [message #646877 is a reply to message #646856] Sat, 01 January 2011 18:05 Go to previous messageGo to next message
J. Michael Dean, M.D. is currently offline J. Michael Dean, M.D.
> Thanx,
> Tom
Not sure what you tried to do. Go to http://www.eclipse.org/downloads
from your iMac and you should see a screen filled with binary packages
ready to install on Mac OS X. Click on the desired distribution and
everything should be essentially automatic.
- Mike
Re: how to install Eclipse on Mac OSX? [message #646909 is a reply to message #646856] Sun, 02 January 2011 22:46 Go to previous messageGo to next message
Rao Kat is currently offline Rao Kat
I have the same issue. Pl update here, if you get a solution.
Thank you
News Website Website
Windshield Repair Houston Windshield Repair Missouri City
[Updated on: Mon, 10 January 2011 12:55]
Report message to a moderator
Re: how to install Eclipse on Mac OSX? [message #647005 is a reply to message #646909] Mon, 03 January 2011 18:39 Go to previous messageGo to next message
Rao Kat,
It appears there are only tarballs, no .dmg's.
Get a proper tarball (I got eclipse-jee-helios-SR1-macosx-cocoa-x86_64.tar)
You may have to first install Xcode from your installations disks to get all Java and devel stuff.
You can install eclipse locally:
open a terminal, and cd ~/Development/ (assuming you have a devel dir).
type the command `tar xf ~/Downloads/eclipse-jee-helios-SR1-macosx-cocoa-x86_64.tar` (or wherever the tarball is)
This will unpack into an eclipse subdir. In it there is an eclipse.app . You can start it from there, or drag it to the toolbar.
Alternatively you can install it for the system:
Log in with an admin account, and open a terminal.
If you activated root, switch to root (`su -`).
Otherwise you should be able to use sudo: `sudo -l`.
cd /Applications
sudo tar xf ~/Downloads/eclipse-jee-helios-SR1-macosx-cocoa-x86_64.tar
Again you get an eclipse subdir.
When I did it ownership was all wrong, fix it:
`chmod -R root:wheel eclipse`
The eclipse application should now show up among applications in the eclipse subdir.
HTH,
Tom
Re: how to install Eclipse on Mac OSX? [message #688325 is a reply to message #647005] Fri, 24 June 2011 08:42 Go to previous messageGo to next message
fgsanz  is currently offline fgsanz
A small correction, for changing the ownership do this:
chown -R root:wheel eclipse
not this:
Re: how to install Eclipse on Mac OSX? [message #830876 is a reply to message #646856] Wed, 28 March 2012 02:54 Go to previous messageGo to next message
Lee Courtney is currently offline Lee Courtney
The install process outlined here: www.cs.dartmouth.edu/~cs5/install/eclipse-osx/index.html
worked quickly and easily to install Indigo Service Release 2 on my MacBook Pro running Mac OS X Lion 10.7.3 (11D50d). Note that I only ran the instructions up thru the install, I did not go into the configuration instructions.
HTH - Lee C.
Re: how to install Eclipse on Mac OSX? [message #1060631 is a reply to message #830876] Mon, 27 May 2013 08:00 Go to previous message
Evgeniy Polyak is currently offline Evgeniy Polyak
Lee Courtney wrote on Wed, 28 March 2012 02:54
HTH - Lee C.
does not work Sad(
dialog writen - The program «Eclipse» can not be opened because its author is an unidentified developer.
Previous Topic:Eclipse crashes with exit code 1
Next Topic:Unable to see my program run
Current Time: Tue May 28 04:20:43 EDT 2013
Powered by FUDForum. Page generated in 0.01645 seconds
