| implicit variable declaration in dsl editor with xbase [message #1060462] |
Fri, 24 May 2013 16:14  |
andrea rossi Messages: 12 Registered: April 2013 |
Junior Member |
Hi , this is a part of my dsl grammar :
ReceiveMessage returns xbase::XExpression :
{ReceiveMessage} 'receive message' name=ValidID 'do' body= XBlockExpression
Message returns xbase::XExpression:
SendMessage | ReceiveMessage
XExpressionInsideBlock returns xbase::XExpression:
XVariableDeclaration | XExpression | Message;
In my dsl editor i can write this :
behaviour HelloBehaviour is CyclicBehaviour
{ receive message msg
do {
val i = 5
msg.getContent() // error no declaration of msg
I can't write msg.getContent() in the receive message body because i haven't declare msg.
I would like to write "receive message msg" in dsl editor and can use msg like a variable in the body of receive message.
(e.g implicit declaration : ACLMessage msg )
How can i do it?
Thank you...
[Updated on: Sat, 25 May 2013 19:06] Report message to a moderator
| Re: implicit variable declaration in dsl editor with xbase [message #1060528 is a reply to message #1060462] |
Sun, 26 May 2013 05:02   |
Lorenzo Bettini Messages: 1128 Registered: July 2009 |
> ReceiveMessage returns xbase::XExpression : {ReceiveMessage} 'receive
> Message returns xbase::XExpression: SendMessage | ReceiveMessage
> behaviour HelloBehaviour is CyclicBehaviour { receive message msg do {
> val i = 5
> msg.getContent() // error no declaration of msg }
> I would like can write "receive message msg" in dsl editor and can use
you should write the JvmModelInferrer accordingly, e.g., for receive
message (by the way, do not use terminal symbols with spaces: 'receive'
'message', instead of 'receive message') you can infer a method with
parameter 'msg' and with the appropriate type, and the the XExpression
after 'do' can access msg (once you associated the XExpression to the
body of the inferred method).
Lorenzo Bettini, PhD in Computer Science, DI, Univ. Torino
HOME: http://www.lorenzobettini.it
| Re: implicit variable declaration in dsl editor with xbase [message #1060598 is a reply to message #1060528] |
Mon, 27 May 2013 04:55   |
Junior Member |
Thank you for your advices...
I don't use JvmModelInferrer for receive message but extend XBaseCompiler
This is a part of my class that extend XbaseCompiler :
override protected doInternalToJavaStatement(XExpression expr, ITreeAppendable it, boolean isReferenced) {
switch expr {
ReceiveMessage : {
if (expr.filter != null){
newLine
append ('''MessageTemplate mt = null; ''')
newLine
append ('''mt = ''' )
append('''«createTemplate(expr.filter as Expression,it)» ;''')
newLine
append('''
jade.lang.acl.ACLMessage msg = myAgent.receive(mt); ''')
else { newLine append('''jade.lang.acl.ACLMessage msg = myAgent.receive()''')}
newLine
append('''if (msg!=null){ ''')
increaseIndentation()
doInternalToJavaStatement(expr.body, it, isReferenced)
append('''} ''')
decreaseIndentation()
newLine
append('''else { block(); }''')
I call doInternalToJavaStatement method and pass ReceiveMessage body.
How i can set implicit variable declaration here?
thank you in advance
[Updated on: Mon, 27 May 2013 04:59] Report message to a moderator
| Re: implicit variable declaration in dsl editor with xbase [message #1060628 is a reply to message #1060598] |
Mon, 27 May 2013 07:31  |
Try to use JvmModelInferrer whenever possible since you'll get for free
correct scoping!
You can have a customized XbaseCompiler to deal with your custom
XExpression (if you have any) or invoke XbaseCompiler directly if you
want to generate code before and after the actual XExpression's
translation... but for the rest, try to use JvmModelInferrer
I don't know whether this http://www.rcp-vision.com/?p=4089 might help you
Lore
On 05/27/2013 10:55 AM, andrea rossi wrote:
> Thank you for you advices...
> switch expr {
> ReceiveMessage : {
> newLine
> newLine append ('''mt = ''' )
> newLine append('''
> newLine append('''if (msg!=null){ ''')
> append('''} ''') decreaseIndentation()
> newLine append('''else { block(); }''')
> How can set implicit variable declaration here?
FUDForum. Page generated in 0.02052 seconds
