| Using a File located in workspace during Validation process [message #1060591] |
Mon, 27 May 2013 04:17 |
Christophe g Messages: 4 Registered: March 2013 |
Junior Member |
Hello
I have a little question I couldn't solve so far.
I'm using ETL and EVL to perform a transformation on my generated model from Xtext. I use them as standalone through a call in the validation process from the embedded Eclipse workspace.
In order to work, both ETL and EVL needs to be provided a "File" instance of a file located on a folder of the "Xtext Eclipse".
I use the "platform:" URI code to access file from the embedded Eclipse workspace.
How can I create a File instance of a file in my xtext.base folder, without having to provide the full path to the file ?
I know the issue might sound Epsilon-related rather then Xtext-related, but the problem is just about loading a file, from Xtext validation process, so I thought here would be a better place to get some help.
Thanks for your help.
Best reguards,
Christophe
[Updated on: Mon, 27 May 2013 04:23] Report message to a moderator
FUDForum. Page generated in 0.02308 seconds
