Home » Eclipse Projects » e(fx)clipse » Eclipse4 with JavaFx using efxClipse
Eclipse4 with JavaFx using efxClipse [message #1053860] Tue, 07 May 2013 18:47 Go to next message
Alex Kipling is currently offline Alex Kipling
I followed Tutorial4 here: http://www.efxclipse.org/trac/wiki/Tutorial4
to create a JavaFx Aplication
I Added 1 Trimmed Window to the Aplication.e4xmi
Problem:
Indeed, when I launch the product - the applicaiton starts, the preview in the superbar show a window, see pic
http://i520.photobucket.com/albums/w327/schajtan/2013-05-08_00-40-15_zpsad39fc8a.png
But when I click on the application in the superbar - nothing happens. The window does not show up.
OS:
Wndows 7 X64
Java 1.7.0_21-b11 X64
Re: Eclipse4 with JavaFx using efxClipse [message #1053861 is a reply to message #1053860] Tue, 07 May 2013 18:51 Go to previous messageGo to next message
Sopot Cela is currently offline Sopot Cela
The X,Y and width/height of the created window get some default value which is inconsistent with the fx renderers. Use 10,10 for x,y and e.g. 300, 500 for w/h.
Re: Eclipse4 with JavaFx using efxClipse [message #1060468 is a reply to message #1053861] Fri, 24 May 2013 18:06 Go to previous messageGo to next message
Thnx Sopot, but using 10,10 for x,y and 300, 500 for w/h. did not work.
Any other ideas?
Which plugin is responsible for providing the JavaFx renderers?
Where can I lookup the right position / size?
Is there any tutorial about using JavaFx with e4 which is up to date and workin?
Greetz
Re: Eclipse4 with JavaFx using efxClipse [message #1060531 is a reply to message #1060468] Sun, 26 May 2013 06:12 Go to previous messageGo to next message
Do you get anything in the log?
Re: Eclipse4 with JavaFx using efxClipse [message #1060583 is a reply to message #1060468] Mon, 27 May 2013 03:41 Go to previous message
Thomas Schindl is currently offline Thomas Schindl
Are you sure you are not coming now from a restored state - I'd suggest
to ask at e(fx)clipse and JavaFX questions on our forum [1] or the
newsgroup at eclipse.org (eclipse.efxclipse).
I've also filed https://bugs.eclipse.org/bugs/show_bug.cgi?id=409112 to
deal with this IMHO extremly dumb SWT-Default settings for x/y.
Tom
[1]https://groups.google.com/forum/?fromgroups=#!forum/efxclipse
> Any other ideas?
> workin?
> Greetz
Previous Topic:Welcome to eclipse.efxclipse
Current Time: Mon May 27 22:47:27 EDT 2013
Powered by FUDForum. Page generated in 0.01660 seconds
