I do have an already existing XText grammr to which corresponds an ECORE meta-model and I am developing a Graphiti editor for it. Now I'd like to drag and drop elements from a model, instance of this meta-model, to the Graphiti editor. The problem is that I'd like the XText outline to be active at the same time of the Graphiti editor. What instead happens is that the when I select the Graphiti editor I get an empty outline.
Michael Wenz Messages: 1275 Registered: July 2009 Location: Walldorf, Germany
Andrea,
the examples.common plugin implements an exemplary outline. See packages
org.eclipse.graphiti.examples.common.outline and
org.eclipse.graphiti.examples.common.outline.tree.
This should give you an idea how to activate the outline page you want to
see.
