Home » Modeling » Papyrus » Adding new buttons in Papyrus Palette
icon5.gif  Adding new buttons in Papyrus Palette [message #1003992] Tue, 22 January 2013 06:37 Go to next message
Walid Ban is currently offline Walid Ban
Hello everybody,
My purpose is to add new buttons in Papyrus Palette (e.g Class diagram) that are linked to stereotypes defined in My profile. It means that i want to automate the stereotype application on the diagram element: Just drag the new created button (e.g class stereotyped) to the Diagram Editor.
Please can you give me Ideas where and how the code modification will be??
For Info:
1) Since the code imported by "http://download.eclipse.org/modeling/mdt/papyrus/psf/subclipse/plugins_http.psf" contains bugs that didn't allow me to create an UML Model, I have used the code imported from "https://speedy.supelec.fr/Papyrus/svn/Papyrus/core/branch/1.11.X/".
2) Palette customization is not an efficient solution because it works only in the current Model where the palette was customized.
Thank you....
Re: Adding new buttons in Papyrus Palette [message #1059547 is a reply to message #1003992] Mon, 20 May 2013 08:00 Go to previous messageGo to next message
Leila A is currently offline Leila A
Dear Walid Ban
Can you please let me know if you succeed to modify palette at run time and how did you handle it? I have been working on it for about 2 weeks and I still I don't know what to do Sad
Thanks and regards,
Leila
Re: Adding new buttons in Papyrus Palette [message #1060390 is a reply to message #1059547] Fri, 24 May 2013 08:28 Go to previous messageGo to next message
Hi Layla,
I modified the palette through "Palette Customization" and not through modifying the code.
1) i followed this Tutoriel: PapyrusDevelopperTutorial_OnPaletteCustomization_v1.0_d2010-05-10.odt
located in : http://dev.eclipse.org/svnroot/modeling/org.eclipse.mdt.papyrus/branches/0.9.X/doc/DevelopperDocuments/How-To/
2) create a plugin in which you create a folder and put you customized palette XML file as shown in the tutoriel(follow the steps). Then install this plugin. This let you o use the paltte in every Papyrus Project you create.
The PDF File i attached can help you to understand.
For info: if you use Eclipse Kepler or Juno version, some details will be modified when creating the plugin. This discussion can help you: http://www.eclipse.org/forums/index.php/m/1014404/#msg_1014404
Good luck Smile
Re: Adding new buttons in Papyrus Palette [message #1060570 is a reply to message #1003992] Mon, 27 May 2013 02:42 Go to previous messageGo to next message
Thanks dear Walid! Smile
But I need to change the palette programmatically Sad
Leila
Re: Adding new buttons in Papyrus Palette [message #1060610 is a reply to message #1060570] Mon, 27 May 2013 06:10 Go to previous message
Aha ok..Smile
Me too i thought i 've got to change the code, but i think the result in the end is the same. that's why i followed the easiest way
regards
Previous Topic:model validation problem sequence diagram
Current Time: Tue May 28 03:02:08 EDT 2013
Powered by FUDForum. Page generated in 0.01606 seconds
