Home » Modeling » Papyrus » Why is a (member)function not an action or activity?
Why is a (member)function not an action or activity? [message #1060545] Sun, 26 May 2013 11:19 Go to next message
Joost Kraaijeveld is currently offline Joost Kraaijeveld
The subject says it more or less: why is a(n) (object member) function
not an action or activity and hence selectable as the action or
behaviour execution specification?
TIA
Joost
Re: Why is a (member)function not an action or activity? [message #1060568 is a reply to message #1060545] Mon, 27 May 2013 01:56 Go to previous message
Marc-Florian Wendland is currently offline Marc-Florian Wendland
Hi Joost,
because the Action-/BehaviorExecutionSpecification does not mean that only
the invoked BehavioralFeature (Message.signature) can be executed or
invoked. You can actually add every accessible Behavior/Action by the
receiving Lifeline (or its represented part) as target of
Action-/BehaviorExecutionSpecification.
This is somehow similar to Transitions where the effect can be used to
specify any additional action that shall be executed once the transition is
taken.
Marc-Florian
"Joost Kraaijeveld" wrote in message news:knt968$t9v$1@xxxxxxxxe.org...
TIA
Joost
Previous Topic:Cannot populate composite diagram with d&d (Kepler rc1)?
Next Topic:model validation problem sequence diagram
Current Time: Tue May 28 02:58:04 EDT 2013
Powered by FUDForum. Page generated in 0.01631 seconds
