Home » Modeling » ATL » Problem with ATL transformation BPMN2PN
Problem with ATL transformation BPMN2PN [message #1060556] Sun, 26 May 2013 15:05 Go to next message
achraf lyazidi is currently offline achraf lyazidi
Hello everybody,
i've already program a BPMN.ecore and a PetriNet.ecore (i did the BPMN.ecore by myself because it's not found in any website, and there is no standard Ecore yet as i know). After that, i wrote my ATL file BPMN2PN.atl, and an XMI file in order to transform it from a BPMN model to a PetriNet model, but i get the following problems :
1- ClassNotFoundException : Class 'Process' in not found or is abstract
2- PackageNotFoundException : Package with uri 'BPMN' not found
(Note that i did specify an nsURI to my BPMN)
I did try to write my model example in .ecore, but the source model is not generated
can you help me please.
Achraf.
Re: Problem with ATL transformation BPMN2PN [message #1060676 is a reply to message #1060556] Mon, 27 May 2013 12:19 Go to previous message
Hugo Bruneliere is currently offline Hugo Bruneliere
You should try to use the BPMN2 metamodel (in Ecore) and modeler to get your BPMN models.
Then, you should be able to reuse them properly in your transformation.
Note that, if your metamodel in Ecore has not been first registered/loaded into the Eclipse registry, you cannot access it via its URI (and you have to specify the file path instead in your ATL launch configuration).
Hugo Bruneliere - R&D Engineer
AtlanMod research team (Inria, EMN & LINA)
Ecole des Mines de Nantes
Nantes - France
Previous Topic:Comparing Large Numbers Fails with ATL 3.2.1
Next Topic:many attributes Source en one target attribute
Current Time: Tue May 28 09:48:10 EDT 2013
Powered by FUDForum. Page generated in 0.01613 seconds
