Home » Eclipse Projects » Equinox » How to create an Application/Product from OSGi Framework Run Configuration?
How to create an Application/Product from OSGi Framework Run Configuration? [message #1060550] Sun, 26 May 2013 11:59
Erwin Hogeweg is currently offline Erwin Hogeweg
How do I convert/export a 'pure' OSGi Framework Run Configuration into something that can easily be distributed?
I can copy the Configuration Area and add a script to start the entire thing, but it seems to me there is a better way to do that.
None of the tutorials I found on creating Applications and Products seem to take the OSGi Framework as a starting point.
As always, your help is highly appreciated.
Kind Regards,
Erwin
Previous Topic:Equinox Launcher and LD_LIBRARY_PATH
Current Time: Mon May 27 22:59:57 EDT 2013
Powered by FUDForum. Page generated in 0.01540 seconds
