Home » Modeling » Papyrus » What's the correct way of using "ref" in a sequence diagram with parameters?
What's the correct way of using "ref" in a sequence diagram with parameters? [message #1060517] Sat, 25 May 2013 18:17 Go to next message
Joe I is currently offline Joe I
I want to reuse e.g. one sequence diagram with one parameter within several sequence diagrams (which are methods of classes) and all use different arguments.
So what is the correct way of modeling something like that?
Example:
Class A:
method1()
method2()
associated with class B:
methodB(+in:C)
Two different InstanceSpecifications of class C are used within method1/2 as arguments for calling methodB. Method1/2 should be sequence diagrams and they call the reusable sd (that of course calls methodB).
I know the answer would be long, maybe someone could provide an example papyrus project from which I can learn... I attached an example project with the classes I explained.
Thanks for help!
[Updated on: Sat, 25 May 2013 18:19]
Report message to a moderator
Re: What's the correct way of using "ref" in a sequence diagram with parameters? [message #1060529 is a reply to message #1060517] Sun, 26 May 2013 05:07 Go to previous message
It seems that it is not possible with Papyrus to define InteractionUse(ref) arguments.
I suppose I have to use/misuse the name of InteractionUse for defining parameters?
Previous Topic:DSML validation functionality
Next Topic:Cannot populate composite diagram with d&d (Kepler rc1)?
Current Time: Tue May 28 16:38:50 EDT 2013
Powered by FUDForum. Page generated in 0.01633 seconds
