Home » Modeling » QVT-OML » Stereotypes and multi-valued attributes(Can't get the value of a multi-valued attribute defined in a Stereotype)
| Stereotypes and multi-valued attributes [message #1060191] |
Thu, 23 May 2013 08:59  |
Matteo M. Messages: 16 Registered: May 2012 |
Junior Member |
Dear all,
I've defined a Stereotype, MyStereo, with a multi-valued attribute (1..*, Integer), mvAttrib. I've applied the Stereotype to an element in my model, myElem, and I've been able to set its multi-value (3,5,1) through Papyrus.
Now, In a QVTo transform, I want to get back these values. I tried with
myElem.getValue(MyStereo, "mvAttrib")
but it returns a Bag(OclAny)[1] element, where the sole value in the returned element is 3 (i.e., the first one I set for mvAttrib). How do I retrieve ALL the values in a multi-value attribute of a Stereotype?
Side question: As I said, I've been able to set the multi-value through Papyrus. How do I set it in QVTo? I tried with
myElem.setValue(MyStereo, "mvAttrib", Sequence{3,5,1})
but the interpreter complains about "Cannot find operation (setValue(Stereotype, String, Sequence(Integer))) for the type ..."
Thanks and best regards,
Matteo
| Re: Stereotypes and multi-valued attributes [message #1060197 is a reply to message #1060191] |
Thu, 23 May 2013 09:06   |
Ed Willink Messages: 3191 Registered: July 2009 |
You assume that you have declared your'multi-value' myElem correctly. No
idea what a 'multi-value' is; I guess that you mean collection.
But since you haven't shared the declaration of myElem with us it is
difficult to comment.
You can save everyone a lot of time with a simple zipped project that
demonstrates your problem.
REgards
Ed Willink
On 23/05/2013 13:59, Matteo M. wrote:
> Dear all,
> through Papyrus.
> Matteo
| Re: Stereotypes and multi-valued attributes [message #1060224 is a reply to message #1060216] |
Thu, 23 May 2013 11:15   |
Junior Member |
This is the link:
https://www.dropbox.com/s/pu7c3mzd3ruz8ab/MyProjects.zip
Let me explain how you (or others) can reproduce the issue.
Please unzip MyProjects.zip. There are 2 projects:
- MyProjectSysML
- MyProjectM2M
In MyProjectSysML you'll find a profile (model.profile) that defines the Stereotype MyStereo with the multi-valued attribute mvAttrib (1..*, Integer (from UML standard types)). Then you'll find the source model (model) that contains a SysML block, myElem, stereotyped as MyStereo. I set the values of mvAttrib of myElem through the Papyrus UI. I gave the values 3,5,1. Finally, you'll find an empty model, that is the target of the M2M transform.
In MyProjectM2M you'll find the QVTo transform (NewTransformation). Please set up your config so as MyProjectSysML/model.uml is your source model and MyProjectSysML/emptyModel.uml is your destination model. Then debug the QVTo transform (only debug the transform or you won't see anything; this is only a trivial example). You'll see that at line 11, the instruction
var mvAttribValues := myElem.getValue(MyStereo, "mvAttrib");
will put only the Integer value 3 in mvAttribValues and not the sequence (?) 3,5,1. How do I get all the values (3,5,1) of mvAttrib?
Matteo
| Re: Stereotypes and multi-valued attributes [message #1060231 is a reply to message #1060224] |
Thu, 23 May 2013 11:53   |
As I suspected, it is the declaration of myElem that is at fault.
var myElem : Class := MyModel.ownedElement->select(e |
e.oclIsKindOf(Class))->oclAsType(Class)![name = "myElem"];
I'm not a fan of ! [] cuteness so I had to look them up and the
documentation is pretty thin.
Your code does not match the
list->prop![startswith("_")]) ; // calling collectselectOne(i;res=
i.prop | not res.startswith("_"))
template, so maybe it's illegal; who knows. Using common sense one might
like it to be
.ownedElement
->select(e | e.oclIsKindOf(Class))
->oclAsType(Class)
->collectselectOne(not (name = "myElem"))
which might mean myElem is a random Class not named myElem. Not what you
wanted.
I find the pure OCL.
e.oclIsKindOf(Class))->oclAsType(Class)->any(name = "myElem");
clearer. As from Indigo you can do
MyModel.ownedElement->selectByKind(Class)->any(name = "myElem");
Ed Willink
On 23/05/2013 16:15, Matteo M. wrote:
> This is the link:
> - MyProjectSysML
> - MyProjectM2M
> Matteo
| Re: Stereotypes and multi-valued attributes [message #1060257 is a reply to message #1060231] |
Thu, 23 May 2013 13:13   |
Reading more carefully; the declaration and pseudo code of
collectselectOne clearly returns a Sequence, so you should have a syntax
error when assigning to a Class. Please raise a Bugzilla.
Ed Willink
On 23/05/2013 16:53, Ed Willink wrote:
> Hi
> might like it to be
> .ownedElement
> ->oclAsType(Class)
> you wanted.
> Regards
> Ed Willink
>> This is the link:
>> - MyProjectSysML
>> - MyProjectM2M
>> Matteo
| Re: Stereotypes and multi-valued attributes [message #1060527 is a reply to message #1060364] |
Sun, 26 May 2013 04:48  |
Sergey Boyko Messages: 147 Registered: July 2009 |
Hi Matteo,
The problem is that the return type of method .getValue() is java.lang.Object which is mapped to OclAny type.
QVTo is based on OCL 2.0 implementation which states that:
"All types in the UML model and the primitive types in the OCL standard library comply with the type OclAny.
Conceptually, OclAny behaves as a supertype for all the types except for the OCL pre-defined collection types."
Despite the fact that .getValue() returns List object for multivalued attribute OCL implementation internally coerces this List into single object (specifically OCL implementation fetches and returns the first element from the list).
More over due to specification it is impossible to convert OclAny type to Collection type (by means of .oclAsType() call).
Btw, current OCL 2.3.1 specification states that:
"All types in the UML model and the primitive and collection types in the OCL standard library conforms to the type
OclAny. Conceptually, OclAny behaves as a supertype for all the types."
However OCL implementation which is used by QVTo doesn't support that.
There are two ways to overcome the problem.
1. Provide Java blackbox library methods .getMultivalue() / .setMultivalue which operate with collections.
2. Use extended syntax of .getValue() / .setValue() that is supported by UML.
For example, to fetch second element from the multivalued attribute one should write the following call:
var v : Integer := myElem.getValue(MyStereo, "mvAttrib[1]").oclAsType(Integer);
For example, to set third element to the multivalued attribute one should write the following call:
myElem.setValue(MyStereo, "mvAttrib[2]", 11);
or
myElem.setValue(MyStereo, "mvAttrib[2]", "11");
UML also supports syntax for association navigation by means of '::' separator in attribute name. For example (in case the 'mvAttrib' is of type of Classifier):
myElem.setValue(MyStereo, "mvAttrib[2]::subAttrib[1]", 11);
Sergey.
Current Time: Tue May 28 20:34:41 EDT 2013
Powered by FUDForum. Page generated in 0.02355 seconds
