Home » Newcomers » Newcomers » Outline view uses red square for some icons
Outline view uses red square for some icons [message #1060490] Sat, 25 May 2013 07:02 Go to next message
Malte Forkel is currently offline Malte Forkel
Why might the outline view use red squares for some icons ("Sort by name", "Collapse all", "Expand all") while others (e.g., "Focus on Active Task") are still fine? This happens in all perspectives, but not in a different workspace. I'm using Juno Service Release 2 (20130225-0426).
Re: Outline view uses red square for some icons [message #1060494 is a reply to message #1060490] Sat, 25 May 2013 07:58 Go to previous messageGo to next message
Ed Merks is currently offline Ed Merks
When it can't locate an icon it will use a red square. This suggests
there is something corrupt with your installation.
> (20130225-0426).
Re: Outline view uses red square for some icons [message #1060512 is a reply to message #1060494] Sat, 25 May 2013 14:35 Go to previous message
I eventually realized that the problem only occurs when a Python source file was selected. I checked the PyDev plugin sources and noticed that there was no folder 'icons' in 'org.python.pydev.shared_ui_2.7.4.2013051601'. After I had inserted a copy of that folder from the PyDev Git repository, the outline view looked fine again.
Previous Topic:I have lost the Menue Iteam Team
Next Topic:.product file write error
Current Time: Tue May 28 04:23:06 EDT 2013
Powered by FUDForum. Page generated in 0.01474 seconds
