Home » Modeling » TMF (Xtext) » Encoding related error in Xtend 2.4
Encoding related error in Xtend 2.4 [message #1030083] Sat, 30 March 2013 13:00 Go to next message
Axel Guckelsberger is currently offline Axel Guckelsberger
Hi all,
when starting the generator using the new versions of MWE and Xtend the
console log gets filled up with stacktraces of java.io.FileNotFoundException
for each generated file.
Looking like this:
9359 [main] ERROR esource.generic.XMLEncodingProvider  - Error detecting
encoding for file:/home/.../some/file
java.io.FileNotFoundException: /home/.../some/file (No such file or
directory)
	at java.io.FileInputStream.open(Native Method)
	at java.io.FileInputStream.<init>(FileInputStream.java:137)
org.eclipse.emf.ecore.resource.impl.FileURIHandlerImpl.createInputStream(FileURIHandlerImpl.java:99)
org.eclipse.emf.ecore.resource.impl.ExtensibleURIConverterImpl.createInputStream(ExtensibleURIConverterImpl.java:354)
org.eclipse.emf.ecore.resource.impl.ExtensibleURIConverterImpl.createInputStream(ExtensibleURIConverterImpl.java:348)
org.eclipse.xtext.resource.generic.XMLEncodingProvider.getEncoding(XMLEncodingProvider.java:32)
org.eclipse.xtext.generator.JavaIoFileSystemAccess.getEncoding(JavaIoFileSystemAccess.java:140)
org.eclipse.xtext.generator.JavaIoFileSystemAccess.generateFile(JavaIoFileSystemAccess.java:81)
org.eclipse.xtext.generator.AbstractFileSystemAccess.generateFile(AbstractFileSystemAccess.java:75)
Basically the problem occurs in XMLEncodingProvider#getEncoding() which
creates an input stream without checking properly if the file exists before.
Did I forget to setup something or is it a bug?
Axel
[Updated on: Sat, 30 March 2013 13:07]
Report message to a moderator
Re: Encoding related error in Xtend 2.4 [message #1034201 is a reply to message #1030083] Fri, 05 April 2013 02:09 Go to previous messageGo to next message
Any clue?
Axel Guckelsberger wrote:
> Hi all,
> java.io.FileNotFoundException for each generated file.
> Looking like this:
> directory)
> at
> at
> at
> at
> at
> at
> at
> before.
> Axel
Re: Encoding related error in Xtend 2.4 [message #1034230 is a reply to message #1034201] Fri, 05 April 2013 03:08 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian Dietrich
the encoding provider is for reading model (xmi) files. so it may not been optimized for the use in the generator.
sounds like a bug to me.
~Christian
Re: Encoding related error in Xtend 2.4 [message #1060511 is a reply to message #1030083] Sat, 25 May 2013 13:53 Go to previous message
Thanks Christian,
I added bug 409069 for this issue.
Previous Topic:generated launch configuration
Next Topic:Infer from external source
Current Time: Tue May 28 17:08:29 EDT 2013
Powered by FUDForum. Page generated in 0.02747 seconds
