| Virgo / Equinox console usage [message #1049354] |
Thu, 25 April 2013 14:49  |
Franck Mising name Messages: 84 Registered: July 2009 Location: France |
Member |
I am a bit confused with the Virgo console, it seems like most of the commands described in the user guide don't work as expected, for example (1st example in section 8.2):
osgi> vsh:plan list
gogo: CommandNotFoundException: Command not found: vsh:plan
osgi>
Some of the commands in Table 8.1 work (packages)if I issue them without the vhs: prefix; but others don't:
osgi> vhs:plan
gogo: CommandNotFoundException: Command not found: vhs:plan
osgi> plan
gogo: CommandNotFoundException: Command not found: plan
osgi>
What's the story here?
I have a subsidiary question: what is the simplest way to trigger the refresh of a bundle from the Windows command line (batch mode, i.e. without having to open a Virgo console first)?
Thanks!
| Re: Virgo / Equinox console usage [message #1060508 is a reply to message #1060507] |
Sat, 25 May 2013 11:59  |
Member |
Ooops, my bad, I was connecting to the wrong console this time.
So problem solved it seems, here is the wrapup for me:
- forget the vsh: prefix, it doesn't seem needed
- can't coerce args etc doesn't necessarily mean that you are using the wrong syntax, you get that message if the bundle isn't found in the region
- the two regions don't have the same set of commands - e.g. plan is only available in the user region
Moving on to trying to refresh a bundle by name from the command line...
FUDForum. Page generated in 0.01724 seconds
