| generated launch configuration [message #1060497] |
Sat, 25 May 2013 08:24 |
Lorenzo Bettini Messages: 1126 Registered: July 2009 |
when running the mwe2 for the first time, Xtext also generates a launch
configuration with proper MaxPergGen arguments (to avoid out of memory
errors), in the (hidden by default) directory .launch, called "Launch
Runtime Eclipse.launch"
right-clicking on the project, Run As... shows "Eclipse Application" but
selecting this will NOT use the generated launch configuration (it
creates a new launch configuration, alas, without MaxPermGen
arguments)... one has to open the Run Configurations dialog in order to
use the generated launch configuration (and to know about that, since by
default .launch is hidden)...
is that the intended behavior?
cheers
Lorenzo
Lorenzo Bettini, PhD in Computer Science, DI, Univ. Torino
HOME: http://www.lorenzobettini.it
FUDForum. Page generated in 0.01488 seconds
