Home » Modeling » EMF » [CDO] NPE from CDOResourceFolder conflict?
[CDO] NPE from CDOResourceFolder conflict? [message #1060233] Thu, 23 May 2013 11:58 Go to next message
Jack Lechner is currently offline Jack Lechner
Hello again!
I was in desperate need of some conflict resolving mechanisms, so I updated to the RC's of EMF and CDO. Before I start, thanks for all of the updates in that area! Smile
I'm running into a NPE using the CDOMergingConflictResolver. The thing that confuses me about this situation is that I'm not modifying the same objects on either client. The situation that causes this is as follows:
1. Client 1 modifies an object a.
2. Client 2 modifies an object b.
3. Client 1 commits.
4. Client 2 receives the NPE.
5. Client 2 upon trying to commit cannot due to a conflict on the "CDOResourceFolder".
Am I doing something incorrectly? I have never seen reference to a CDOResourceFolder object before. This is the stacktrace, line 139 is "remoteDelta.apply(newCleanRevision);".
	at org.eclipse.emf.spi.cdo.CDOMergingConflictResolver.resolveConflicts(CDOMergingConflictResolver.java:139)
	at org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl.handleConflicts(CDOTransactionImpl.java:743)
	at org.eclipse.emf.internal.cdo.view.CDOViewImpl.doInvalidate(CDOViewImpl.java:883)
	at org.eclipse.emf.internal.cdo.view.CDOViewImpl$InvalidationRunnable.run(CDOViewImpl.java:1661)
	at org.eclipse.net4j.util.concurrent.QueueRunner.work(QueueRunner.java:26)
	at org.eclipse.net4j.util.concurrent.QueueRunner.work(QueueRunner.java:1)
	at org.eclipse.net4j.util.concurrent.QueueWorker.doWork(QueueWorker.java:88)
	at org.eclipse.net4j.util.concurrent.QueueWorker.work(QueueWorker.java:79)
	at org.eclipse.net4j.util.concurrent.Worker$WorkerThread.run(Worker.java:206)
Thanks in advance!
Re: [CDO] NPE from CDOResourceFolder conflict? [message #1060479 is a reply to message #1060233] Sat, 25 May 2013 02:57 Go to previous message
Eike Stepper is currently offline Eike Stepper
Hi Jack,
I'm still working on the CDOMergingConflictResolver because it's not fully implemented, yet. I know it's late in the
cycle but please wait until all the related bugzillas are resolved and then try again. If exception do still occur then,
please submit a bugzilla, so that I can handle it quickly.
Cheers
/Eike
http://www.esc-net.de
Am 23.05.2013 17:58, schrieb Jack Lechner:
> Hello again!
> start, thanks for all of the updates in that area! :)
> java.lang.NullPointerException
> Thanks in advance!
Previous Topic:[XCore] Compiler overrides code tagged as not generated
Next Topic:[CDO] CDOServerExporter and DynamicValueHolder.NIL
Current Time: Tue May 28 11:33:02 EDT 2013
Powered by FUDForum. Page generated in 0.01684 seconds
