Home » Eclipse Projects » BPMN 2.0 Modeler » Example Custom Task screencast tutorial now available
Example Custom Task screencast tutorial now available [message #1008335] Mon, 11 February 2013 18:16 Go to next message
Robert Brodt is currently offline Robert Brodt
Hi all,
I've put together a screencast tutorial that builds an extension plug-in for the editor using the <customTask> extension point. Please have a look and leave comments here.
Cheers!
Bob
Re: Example Custom Task screencast tutorial now available [message #1060239 is a reply to message #1008335] Thu, 23 May 2013 12:16 Go to previous messageGo to next message
reg bas is currently offline reg bas
Bob know what happens to me with the screencast, but i wanna know if some other member of the forum have the same problem.
I follow step by step the screencast but at the end I drag the CustomTask but this don't appear in the diagram. I try with eclipse Indigo, Juno in Windows 7 and in Fedora with eclipse Juno.
Someone have the same problem?
Thanks!
Re: Example Custom Task screencast tutorial now available [message #1060297 is a reply to message #1060239] Thu, 23 May 2013 21:39 Go to previous messageGo to next message
If I download the sample code from github and run, it works perfectly!
[Updated on: Thu, 23 May 2013 21:39]
Report message to a moderator
Re: Example Custom Task screencast tutorial now available [message #1060444 is a reply to message #1060239] Fri, 24 May 2013 12:34 Go to previous messageGo to next message
Hi reg-bas,
You have a pull request at github. I was able to get your example running with some minor changes - check the github pull request.
Re: Example Custom Task screencast tutorial now available [message #1060473 is a reply to message #1060444] Fri, 24 May 2013 23:07 Go to previous message
That has solved the problems!
Bob.. thanks!
I'll look what are the bugs in my code. I saw the java version in 1.6... I guess that are the bigger problem no?
Thanks a lot Bob!
Previous Topic:Put a Flag in elements of the BPMN
Current Time: Mon May 27 22:37:21 EDT 2013
Powered by FUDForum. Page generated in 0.01603 seconds
