| a collection of PDT errors on Eclipse Classic 4.2.2 [message #1057985] |
Fri, 10 May 2013 06:46  |
Juris Sudmalis Messages: 9 Registered: March 2011 |
Junior Member |
I've recently started writing some PHP code at home on Eclipse 4.2 and I've noticed that the PHP Development Tools plugin seems to be outdated and doesn't work well with my Eclipse version.
I've received these and more errors in the error log:
1) Help index declared, but missing for plugin org.eclipse.php.help. (no stacktrace)
2) Conflicting handlers for org.eclipse.wst.sse.ui.toggle.comment: {org.eclipse.php.internal.ui.actions.PHPToggleLineCommentHandler@160277c} vs {org.eclipse.wst.sse.ui.internal.handlers.ToggleLineCommentHandler@1c072e9}
This one pops up very frequently when editing a PHP file.
3) offset 16039 is out of [0, 119]
Quote:org.eclipse.jface.text.BadLocationException: offset 16039 is out of [0, 119]
at org.eclipse.php.internal.core.documentModel.parser.regions.PhpTokenContainer.checkBadLocation(PhpTokenContainer.java:453)
at org.eclipse.php.internal.core.documentModel.parser.regions.PhpTokenContainer.getToken(PhpTokenContainer.java:59)
at org.eclipse.php.internal.core.documentModel.parser.regions.PhpTokenContainer.getTokens(PhpTokenContainer.java:105)
at org.eclipse.php.internal.core.documentModel.parser.regions.PhpScriptRegion.getPhpTokens(PhpScriptRegion.java:105)
at org.eclipse.php.internal.core.format.DefaultIndentationStrategy.lineContainIncompleteBlock(DefaultIndentationStrategy.java:486)
at org.eclipse.php.internal.core.format.DefaultIndentationStrategy.isIndentationBase(DefaultIndentationStrategy.java:323)
at org.eclipse.php.internal.core.format.DefaultIndentationStrategy.getIndentationBaseLine(DefaultIndentationStrategy.java:110)
at org.eclipse.php.internal.core.format.DefaultIndentationStrategy.placeMatchingBlanksForStructuredDocument(DefaultIndentationStrategy.java:636)
at org.eclipse.php.internal.core.format.DefaultIndentationStrategy.placeMatchingBlanks(DefaultIndentationStrategy.java:565)
at org.eclipse.php.internal.ui.autoEdit.IndentLineAutoEditStrategy.placeMatchingBlanks(IndentLineAutoEditStrategy.java:190)
at org.eclipse.php.internal.ui.autoEdit.IndentLineAutoEditStrategy.autoIndentAfterNewLine(IndentLineAutoEditStrategy.java:58)
at org.eclipse.php.internal.ui.autoEdit.IndentLineAutoEditStrategy.customizeDocumentCommand(IndentLineAutoEditStrategy.java:124)
at org.eclipse.php.internal.ui.autoEdit.MainAutoEditStrategy.customizeDocumentCommand(MainAutoEditStrategy.java:64)
at org.eclipse.jface.text.TextViewer.customizeDocumentCommand(TextViewer.java:3779)
at org.eclipse.jface.text.TextViewer.handleVerifyEvent(TextViewer.java:3816)
at org.eclipse.jface.text.source.projection.ProjectionViewer.handleVerifyEvent(ProjectionViewer.java:1276)
at org.eclipse.wst.sse.ui.internal.StructuredTextViewer.handleVerifyEvent(StructuredTextViewer.java:761)
at org.eclipse.jface.text.TextViewer$TextVerifyListener.verifyText(TextViewer.java:435)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:273)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1062)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:774)
at org.eclipse.swt.custom.StyledText.modifyContent(StyledText.java:7146)
at org.eclipse.swt.custom.StyledText.sendKeyEvent(StyledText.java:8007)
at org.eclipse.swt.custom.StyledText.doContent(StyledText.java:2467)
at org.eclipse.swt.custom.StyledText.handleKey(StyledText.java:5907)
at org.eclipse.swt.custom.StyledText.handleKeyDown(StyledText.java:5937)
at org.eclipse.swt.custom.StyledText$7.handleEvent(StyledText.java:5629)
at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:1104)
at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:1100)
at org.eclipse.swt.widgets.Widget.wmChar(Widget.java:1521)
at org.eclipse.swt.widgets.Control.WM_CHAR(Control.java:4640)
at org.eclipse.swt.widgets.Canvas.WM_CHAR(Canvas.java:345)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4528)
at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:341)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4976)
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:2546)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3756)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1053)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:942)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:588)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:543)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
4) Unhandled event loop exception
Quote:java.lang.NullPointerException
at org.eclipse.php.internal.ui.editor.PHPStructuredTextAnnotationHover.compareRulerLine(PHPStructuredTextAnnotationHover.java:159)
at org.eclipse.php.internal.ui.editor.PHPStructuredTextAnnotationHover.getMarkerMessages(PHPStructuredTextAnnotationHover.java:307)
at org.eclipse.php.internal.ui.editor.PHPStructuredTextAnnotationHover.getHoverInfo(PHPStructuredTextAnnotationHover.java:239)
at org.eclipse.jface.text.source.AnnotationBarHoverManager.computeInformation(AnnotationBarHoverManager.java:385)
at org.eclipse.jface.text.AbstractInformationControlManager.doShowInformation(AbstractInformationControlManager.java:1131)
at org.eclipse.jface.text.AbstractHoverInformationControlManager$MouseTracker.mouseHover(AbstractHoverInformationControlManager.java:519)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:208)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4169)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3758)
Have any of these errors been resolved in the latest commits to the PDT repository, and if yes, how could I get a build of the latest sources? It seems building Eclipse plugins isn't straightforward and I only need this one plugin, so wasting the time to learn how to do that might not be worth it.
[Updated on: Fri, 10 May 2013 06:47] Report message to a moderator
FUDForum. Page generated in 0.01638 seconds
