Home » Language IDEs » Java Development Tools (JDT) » refresh/update java editor programmatically before jumping to java element
refresh/update java editor programmatically before jumping to java element [message #1060389] Fri, 24 May 2013 08:27 Go to next message
deflow Mising name is currently offline deflow Mising name
hi all!
i'm struggling with a little issue, which i'm not able to fix Sad
may you can help me with this?
here we go:
the only thing i'm trying to do is to open a compilation unit in a java editor an jumping to a specific position (e.g. method xyz()). usually, the method xyz() is going to be created programmatically, just before the jump action.
this all works fine, except for one case:
if the compilation unit is aldready opened in an editor and i'm trying to jump to the "new generated" method xyz(), i'm ending up on a wrong position in editor.
With the following code i'm able to overcome this problem. however i can't imagine that's the way i'm supposed to do it...
IEditorPart javaEditor = JavaUI.openInEditor(element);
[color=red]javaEditor.doSave(null);[/color]
JavaUI.revealInEditor(javaEditor, element);
is there a way to update or refresh the editor before i execute my jump action?
thx in advance
[Updated on: Fri, 24 May 2013 08:28]
Report message to a moderator
Re: refresh/update java editor programmatically before jumping to java element [message #1060448 is a reply to message #1060389] Fri, 24 May 2013 13:02 Go to previous message
Stephan Herrmann is currently offline Stephan Herrmann
Showing the part concerning the editor is only half the story:
How do you create the method? Using a DOM rewriter? By modifying the buffer, the file?
Any working copies involved? Do you reconcile them after modification?
Previous Topic:Reflective Access to @NonNull
Next Topic:How can I implement Eclipse Content Assist feature into my editor?
Current Time: Tue May 28 06:06:40 EDT 2013
Powered by FUDForum. Page generated in 0.01470 seconds
