Home » Modeling » TMF (Xtext) » XBase dependency to xbase.lib
XBase dependency to xbase.lib [message #1060425] Fri, 24 May 2013 11:16 Go to next message
Marc Z is currently offline Marc Z
In order to fully enjoy Xbase syntax, I have to make sure that the org.eclipse.xtext.xbase.lib is included as a dependency in the MANIFEST of the project which consists of my DSL model.
This is only possible, if I create the project as an Eclipse plug-in project.
Is there another way to reference to the xbase.lib having my DSL model in a "normal" (not plug-in) project?
Marc
Re: XBase dependency to xbase.lib [message #1060430 is a reply to message #1060425] Fri, 24 May 2013 11:28 Go to previous messageGo to next message
Ed Merks is currently offline Ed Merks
Marc,
You'd have to add it as a library to the Java Project's build path via
the properties for that Java project. Although I generally feel
compelled to point out to people that there's nothing that prevents a
PDE managed project from being used as an ordinary Java project to build
jars that will not be used with Eclipse. It's so much easier to manage
the dependencies and libraries verses messing directly with the
classpath for each and every project...
On 24/05/2013 5:16 PM, Marc Z wrote:
> project.
> Marc
Re: XBase dependency to xbase.lib [message #1060432 is a reply to message #1060425] Fri, 24 May 2013 11:37 Go to previous message
Sven Efftinge is currently offline Sven Efftinge
Yes, it is in maven central:
http://search.maven.org/#search%7Cga%7C1%7Ca%3A%22org.eclipse.xtext.xbase.lib%22
Am 5/24/13 5:16 PM, schrieb Marc Z:
> project.
> Marc
Need professional support for Xtext or other Eclipse Modeling technologies?
Go to: http://xtext.itemis.com
Twitter : @svenefftinge
Blog : http://blog.efftinge.de
Need professional support for Xtext and EMF?
Blog : blog.efftinge.de
Previous Topic:Creating xtext file as model from GMF
Next Topic:Blog post about Ecore EPackage import as reference
Current Time: Tue May 28 17:09:25 EDT 2013
Powered by FUDForum. Page generated in 0.01447 seconds
