| Re: LLVM Suport [message #1060360 is a reply to message #1060357] |
Fri, 24 May 2013 05:49  |
Thomas Schindl Messages: 4472 Registered: July 2009 |
There is robovm which takes Java-Class files and translates them to
native binaries using LLVM.
Tom
On 24.05.13 11:29, Jan Koehnlein wrote:
> Xtext does not make any assumption on the platform to generate code to.
> It just generates text form your models, which is usually compiled by
> another compiler.
> The generated editor for your Xtext language is based on Eclipse. I am
> not an expert, but I think there is support for the LLVM infrastructure
> in Eclipse CDT. So everything could be integrated in a single Eclipse IDE.
> If you refer to Xbase or Xtend, Java is currently the only supported
> target. We rely heavily on Java's typesystem, so adding another target
> platform will be a lot of work.
> Am 23.05.13 16:10, schrieb Suminda Sirinath Salpitikorala Dharmasena:
>> Is it possible to add LLVM development support for Xtext also ability to
>> traslate to other than just Java.
>> Suminda
FUDForum. Page generated in 0.01674 seconds
