| Qualified Associations [message #1060350] |
Fri, 24 May 2013 04:53  |
Antonio M. Moreno Messages: 6 Registered: November 2012 |
Junior Member |
I'm doing my final degree thesis using Papyrus. Now, I need to represent an example that contains an Qualified Association, similar to the example in the figure 7.1 in OCL Specification.
Is it posible to describe it in Papyrus? Do I need to change the qualified association with another structure?
Thank you in advance!
Antonio
| Re: Qualified Associations [message #1060359 is a reply to message #1060350] |
Fri, 24 May 2013 05:45  |
Ed Willink Messages: 3191 Registered: July 2009 |
Figure 7.1 is seriously challenging.
When I tried a year or more ago, I had to raise some bugs about lack of
support for association classes; hopefully fixed; not sure.
Beyond that, Figure 7.1 and indeed almost the whiole of Section 7 has
many typos in since when written there was no tooling to check it.
Beyond that, if you try to use the OCL you will be in very cutting edge
territory. Qualified associations are very little used and so you may
well encounter tooling inadequacies.
Good luck. Please raise bugs as appropriate.
Ed Willink
On 24/05/2013 09:53, Antonio M. Moreno wrote:
> Antonio
FUDForum. Page generated in 0.01538 seconds
