Home » Modeling » Epsilon » Property Selection Filter on Property Section
Property Selection Filter on Property Section [message #1060344] Fri, 24 May 2013 04:44 Go to next message
serhat gezgin is currently offline serhat gezgin
I have this metamodel;
(i only showing releations)
abstract Field
LookUp extends Field
  contentType -> 1..1 ContentType (referance)
  showField  -> 1..1 Field (reference)
Content Type
     ownedField -> 0..* Field(containment)
here i just want when user select showfield feature from properties section of LookUp Field, GMF must show only its referenced ContentType element Field's. But when i generate GMF it shows all created Field. How can i constraint this ? anyone can help me ?
(Example attached as a picture)
on example LookUp defined and cnn2 ContentType set as its ContentType referance feature. But when i click showField from properties section i must have only 'no' Number Field. But it gives me all fields. But i need only no Number field. How can i do this anyone can help me ?
  • Attachment: LookUp.png
    (Size: 162.24KB, Downloaded 4 times)
Re: Property Selection Filter on Property Section [message #1060358 is a reply to message #1060344] Fri, 24 May 2013 05:41 Go to previous messageGo to next message
Dimitris Kolovos is currently offline Dimitris Kolovos
This appears to be a pure GMF question so I suspect you'd have a better chance of receiving a helpful response in the GMF forum.
Dimitris
Re: Property Selection Filter on Property Section [message #1060376 is a reply to message #1060358] Fri, 24 May 2013 07:07 Go to previous messageGo to next message
sometimes I get a lot of help here than gmf forum so I tried my
luck Smile
Re: Property Selection Filter on Property Section [message #1060405 is a reply to message #1060376] Fri, 24 May 2013 09:52 Go to previous message
solution is on :
http://www.eclipse.org/forums/index.php/m/1059575/#msg_1059575
Previous Topic:EVL diagnostics in Problems View, but no decorators on Diagram
Next Topic:Creating xtext file as model from GMF
Current Time: Tue May 28 12:57:22 EDT 2013
Powered by FUDForum. Page generated in 0.01838 seconds
