Home » Modeling » GMF (Graphical Modeling Framework) » Create Commands Of Elements
Create Commands Of Elements [message #1059182] Fri, 17 May 2013 03:18 Go to next message
serhat gezgin is currently offline serhat gezgin
Hi all,
on attached picture. I show creation command section of Diagram for List element.
But i dont want to show this buttons. So i go to COmmands package and creation class
and modify
	public boolean canExecute() {
		return false;
but when i done this this creation buttons just disabled but they are visible as
before. I just want to dont show this buttons so how can i done this anyone can help
me ?
Re: Create Commands Of Elements [message #1060340 is a reply to message #1059182] Fri, 24 May 2013 04:29 Go to previous message
Ralph Gerbig is currently offline Ralph Gerbig
what is displayed there is influenced by modelling assistant provider. There is an extension point called de.uni_mannheim.informatik.swt.models.plm.diagram.providers.PLMModelingAssistantProvider which supplies all model element for which the service shall be available. If you do not want to add any children via this menu to the container you can remove every occurrence of the container in this extension point. Is this what you want? If you decide to choose this method you might think about modifying the templates of gmf tooling to generate the plugin.xml as you like. Doing it this way you can delete and get regenerated your plugin.xml later which can be quite helpful.
Ralph
Previous Topic:How to dynamically extend palette
Next Topic:Export product
Current Time: Tue May 28 13:30:19 EDT 2013
Powered by FUDForum. Page generated in 0.05071 seconds
