| qualified names on referance labels [message #1053486] |
Mon, 06 May 2013 04:51  |
serhat gezgin Messages: 136 Registered: January 2013 Location: Izmir |
Hi all,
I need qualified name on reference labels but don't know how can i implement this
feature anyone can help me to do ?
Sample scenario is on attached picture
regards.
| Re: qualified names on referance labels [message #1060339 is a reply to message #1053575] |
Fri, 24 May 2013 04:24  |
Hi i found the solution.
we must do this feature on XXXEditor project.
This feature must be implemented to the meta clasess one by one.
Example;
i define a method which returns qualified name of Element (belongs to my model
so if u want to use this u must change this method. Because ContentUnit my abstract class and whole metaclasess extended from ContentUnit and its have name property)
public static String returnQualifiedNameOfElement(EObject object) {
String qualifiedName = "";
while (object.eContainer() != null) {
if (object.eContainer() instanceof ContentUnit)
qualifiedName = ((ContentUnit) object.eContainer()).getName() + "." + qualifiedName;
object = object.eContainer();
return qualifiedName;
and then i use this method on ContentTypeItemProvider.java class. Which automatically generated after gmf. (ContentType is my meta class of my metamodel)
on ContentTypeItemProvider.java class getText() method. (getText() is used for represent property names on editor project) i used above method. like;
public String getText(Object object) {
String label = Util.returnQualifiedNameOfElement((EObject) object) + ((ContentType)object).getName();
return label == null || label.length() == 0 ?
getString("_UI_ContentType_type") :
getString("_UI_ContentType_type") + " " + label;
I hope this helps another who searching qualified name on GMF
[Updated on: Fri, 24 May 2013 07:10] Report message to a moderator
FUDForum. Page generated in 0.01514 seconds
