Home » Newcomers » Newcomers » Eclipse on 64-bit Windows 7 (plz help)
Eclipse on 64-bit Windows 7 (plz help) [message #1059978] Wed, 22 May 2013 08:23 Go to next message
sdsgdvgv vgvgvg is currently offline sdsgdvgv vgvgvg
index.php/fa/15010/0/Can somebody plz help with this error?
Re: Eclipse on 64-bit Windows 7 (plz help) [message #1060119 is a reply to message #1059978] Thu, 23 May 2013 03:52 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin Dahyabhai
Your image didn't make it through. Maybe you could use words?
Nitin Dahyabhai
Eclipse WTP, IBM
Re: Eclipse on 64-bit Windows 7 (plz help) [message #1060159 is a reply to message #1060119] Thu, 23 May 2013 07:36 Go to previous messageGo to next message
index.php/fa/15024/0/
[Updated on: Thu, 23 May 2013 07:36]
Report message to a moderator
Re: Eclipse on 64-bit Windows 7 (plz help) [message #1060160 is a reply to message #1060159] Thu, 23 May 2013 07:37 Go to previous messageGo to next message
sorry
Re: Eclipse on 64-bit Windows 7 (plz help) [message #1060162 is a reply to message #1060160] Thu, 23 May 2013 07:37 Go to previous messageGo to next message
need 5 msg to post link Sad
Re: Eclipse on 64-bit Windows 7 (plz help) [message #1060163 is a reply to message #1060162] Thu, 23 May 2013 07:37 Go to previous messageGo to next message
and there is my pic
Re: Eclipse on 64-bit Windows 7 (plz help) [message #1060164 is a reply to message #1060163] Thu, 23 May 2013 07:37 Go to previous messageGo to next message
http://www.bildites.lv/images/96n2mdanl23aaikzwqgk.jpg
Re: Eclipse on 64-bit Windows 7 (plz help) [message #1060168 is a reply to message #1060164] Thu, 23 May 2013 07:40 Go to previous messageGo to next message
Enrico R. is currently offline Enrico R.
Member
You need a 64Bit Java JRE/JDK to run a Eclipse 64Bit Version.
Re: Eclipse on 64-bit Windows 7 (plz help) [message #1060175 is a reply to message #1060168] Thu, 23 May 2013 08:05 Go to previous messageGo to next message
i just instaled - http://www.filehippo.com/download_jre_64/
restart my pc
and still get thiss erroe http://www.bildites.lv/images/m4a8pc412qtda1rplbba.jpg
[Updated on: Thu, 23 May 2013 08:05]
Re: Eclipse on 64-bit Windows 7 (plz help) [message #1060185 is a reply to message #1060175] Thu, 23 May 2013 08:34 Go to previous messageGo to next message
Member
please read here: http://wiki.eclipse.org/Eclipse.ini
specially the part of "Specifying the JVM"
This is one of the possibilities (in my opinion the easiest way) to specify a JRE/JDK to start eclipse.
Hope that helps.
PS: If u want to write java programs you need a JDK (Java Development Kit) installed.
[Updated on: Thu, 23 May 2013 08:36]
Re: Eclipse on 64-bit Windows 7 (plz help) [message #1060193 is a reply to message #1060185] Thu, 23 May 2013 09:00 Go to previous messageGo to next message
heres my eclipse.ini
-startup
plugins/org.eclipse.equinox.launcher_1.3.0.v20120522-1813.jar
--launcher.library
plugins/org.eclipse.equinox.launcher.win32.win32.x86_64_1.1.200.v20120913-144807
-showsplash
org.eclipse.platform
--launcher.XXMaxPermSize
256m
--launcher.defaultAction
openFile
-vm
C:\Program Files (x86)\Java\jre7\bin\javaw.exe
-vmargs
-Xms40m
-Xmx512m
Re: Eclipse on 64-bit Windows 7 (plz help) [message #1060203 is a reply to message #1060193] Thu, 23 May 2013 09:37 Go to previous messageGo to next message
David Wegener is currently offline David Wegener
That is pointing to a 32 bit JVM. You need to point to the 64 bit JVM. You will need to find where the 64 bit VM was installed and change the line after the -vm line in the eclipse.ini to point to the 64 bit location.
Re: Eclipse on 64-bit Windows 7 (plz help) [message #1060311 is a reply to message #1060203] Fri, 24 May 2013 02:41 Go to previous message
thanks a lot.
i directed eclipse to right java and its worked...
thanks Smile
Previous Topic:How to cancel prompt box: "Undefined variable" ?
Next Topic:Open project path
Current Time: Tue May 28 04:27:52 EDT 2013
Powered by FUDForum. Page generated in 0.07118 seconds
