Home » Newcomers » Newcomers » Is the XSL 'document' function implemented/supported?(XSL open multiple xml documents?)
Is the XSL 'document' function implemented/supported? [message #1060279] Thu, 23 May 2013 15:53
Paul Carew is currently offline Paul Carew
I'm trying to write an XSL transformation that reaeds/transforms an Android layout file to HTML.
Android layout files reference other 'value' xml files for specific values, e.g. strings.xml
I tried using the xsl document funxtion to open the strings.xml file to extract a string value.
However, nothing seems to happen. No errors and no results from the access.
Here is the code snippets:
This is the xsl line that tries to open the strings file and get a value.
<xsl:value-of select="document('../values/strings.xml')/String[@name=substring-after(@android:text,'/')]" />
I also tried placing the strings.xml file in the same directory as the xsl file, but that didn't make any difference.
Any help/insight would be greatly appreciated.
Paul.
Previous Topic:Design View
Next Topic:Looking for Eclipse IDE for C/C++ Developers version from 3.8.0 to 4.0.0
Current Time: Tue May 28 04:29:33 EDT 2013
Powered by FUDForum. Page generated in 0.02795 seconds
