Home » Modeling » ATL » XML2XML
| XML2XML [message #1059470] |
Sun, 19 May 2013 06:23  |
samar sousou Messages: 57 Registered: March 2013 |
Member |
Hi every body,
I have a problem when i want to transform an XML to another XML in ATL.
When i want to translate a root vers the other root, i have this error "Cannot set feature children to value [org.eclipse.emf.ecore.impl.DynamicEObjectImpl@106c28e (eClass: org.eclipse.emf.ecore.impl.EClassImpl@45a13b (name: Attribute) (instanceClassName: null) (abstract: false, interface: false)), org.eclipse.emf.ecore.impl.DynamicEObjectImpl@22610b (eClass: org.eclipse.emf.ecore.impl.EClassImpl@15c4245 (name: Text) (instanceClassName: null) (abstract: false, interface: false)), org.eclipse.emf.ecore.impl.DynamicEObjectImpl@cf16e8 (eClass: org.eclipse.emf.ecore.impl.EClassImpl@e25e24 (name: Element) (instanceClassName: null) (abstract: false, interface: false)), org.eclipse.emf.ecore.impl.DynamicEObjectImpl@1112380 (eClass: org.eclipse.emf.ecore.impl.EClassImpl@15c4245 (name: Text) (instanceClassName: null) (abstract: false, interface: false)), org.eclipse.emf.ecore.impl.DynamicEObjectImpl@122d2ad (eClass: org.eclipse.emf.ecore.impl.EClassImpl@e25e24 (name: Element) (instanceClassName: null) (abstract: false, interface: false)), org.eclipse.emf.ecore.impl.DynamicEObjectImpl@31d83c (eClass: org.eclipse.emf.ecore.impl.EClassImpl@15c4245 (name: Text) (instanceClassName: null) (abstract: false, interface: false)), org.eclipse.emf.ecore.impl.DynamicEObjectImpl@1a71ca6 (eClass: org.eclipse.emf.ecore.impl.EClassImpl@e25e24 (name: Element) (instanceClassName: null) (abstract: false, interface: false)), org.eclipse.emf.ecore.impl.DynamicEObjectImpl@6b5372 (eClass: org.eclipse.emf.ecore.impl.EClassImpl@15c4245 (name: Text) (instanceClassName: null) (abstract: false, interface: false))], inter-model references are forbidden. Configure launching options to allow them."
I didn't understand this error.
So, i need your help and this is my Root rule.
rule ROOT {
from
i : XMLS!Root
to
o: XMLC!Root (
name <- 'donneesMUDU',
startLine <- i.startLine,
startColumn <- i.startColumn,
endLine <- i.endLine,
endColumn <- i.endColumn,
children <- i.children
what should i do!
Thank you,
Samar
| Re: XML2XML [message #1059554 is a reply to message #1059470] |
Mon, 20 May 2013 08:37   |
Hugo Bruneliere Messages: 469 Registered: July 2009 |
The error message says "inter-model references are forbidden. Configure launching options to allow them".
You should try to set the corresponding option to yes in your launch configuration and then run your transformation again.
Maybe this could solve your problem.
Hugo Bruneliere - R&D Engineer
AtlanMod research team (Inria, EMN & LINA)
Ecole des Mines de Nantes
Nantes - France
| Re: XML2XML [message #1059696 is a reply to message #1059576] |
Tue, 21 May 2013 05:04   |
You first have to ensure that, in your XML.ecore file (i.e. your XML metamodel), the "children" reference is actually a containment one.
Then, this can also depends on your input model (is it correct?) and on the other rules in your transformation.
Nantes - France
| Re: XML2XML [message #1059748 is a reply to message #1059724] |
Tue, 21 May 2013 09:57   |
Have you checked your input model as I told you before?
If you obtain such an output model according to your described transformation rule (which is basically a simple "Root element copy" rule), this means that you also have the same several Root elements in your input model.
Nantes - France
| Re: XML2XML [message #1059787 is a reply to message #1059768] |
Tue, 21 May 2013 11:28   |
In your transformation, do you have only one rule matching elements of type Root (i.e. the one in the first post of this conversation)?
If yes, I cannot understand why ATL would create several Root elements in your output model from one Root element in your input model...
Nantes - France
| Re: XML2XML [message #1060048 is a reply to message #1060004] |
Wed, 22 May 2013 12:15   |
The transformation you've just shown in your last post is not the same than the one shown in your original post: please, in the future, be sure to provide the right transformation when asking your questions otherwise it is not possible for the community to provide you a good answer.
Anyway, the result model you obtain is normal according to the specified transformation: you are asking for a matching on each tuple of the Cartesian product between the Root and Element elements of your input model (as you have two elements in the rule input pattern), so you get in output as much Root elements as you have of Element elements in input.
If you go back to the initial ROOT rule (cf. your first post), you will get only one Root element in your output model.
You then have to create another rule to match the Element elements, etc.
Nantes - France
| Re: XML2XML [message #1060138 is a reply to message #1060096] |
Thu, 23 May 2013 05:32   |
As I already said in my previous post:
So you should have a dedicated rule to deal with Element elements, another rule to deal with the Attribute elements, etc. The overall structure of your transformation should look like the following (please read carefully the ATL user guide that explains everything with a lot of details):
rule RootToRoot {
from
i: XMLS!Root
to
o : XMLC!Root (
name <- i.name,
children <- i.children->union(Sequence{comp})
comp:XMLC!Element(
name <- 'Composant',
children <- Sequence{tyComp}
tyComp:XMLC!Attribute(
name <- i.getCN('TypC')
rule ElementToElement {
from
i: XMLS!Element
to
o : XMLC!Element (
rule Attribute2Attribute {
from
i: XMLS!Attribute
to
o : XMLC!Attribute (
Etc.
Nantes - France
| Re: XML2XML [message #1060181 is a reply to message #1060138] |
Thu, 23 May 2013 08:13   |
Member |
Thank you very much,
but when i run this code
-- @path XMLC=/XML2XMLproject/M2/XML.ecore
-- @path XMLS=/XML2XMLproject/M2/XML.ecore
module xml2xmlpropose;
create OUT : XMLC from IN : XMLS;
helper context XMLS!Root def : getCN(a:String) : String =
let e:Sequence(XMLS!Element)=
self.getChildrenbyName('N')->asSequence()
in
if e->notEmpty()
then
e->first().getchildren(a)
else
endif
helper context XMLS!Element def: getStringAttrValue(attrName : String) : String =
let eltC : Sequence(XML!Attribute) =
self.children->select(a | a.oclIsTypeOf(XMLS!Attribute) and a.name = attrName)->asSequence()
in
if eltC->notEmpty()
then
eltC->first().value
else
endif;
helper context XMLS!Root def : getChildrenbyName(attr:String) : Set(XMLS!Element) =
self.children->select(a | a.oclIsTypeOf(XMLS!Element) and a.name=attr)->asSequence()
helper context XMLS!Element def : getchildren(a:String) : String =
self.children->select(b |b.oclIsTypeOf(XMLS!Element)and b.name='C')->asSequence()
in
if e->notEmpty()
then
e->first().getStringAttrValue(a)
else
endif
rule RootToRoot {
from
i: XMLS!Root
to
o : XMLC!Root (
name <- i.name,
comp:XMLC!Element(
from
i: XMLS!Element
to
o : XMLC!Element (
name <- i.name
from
i: XMLS!Attribute
to
name <- i.name,
value <- i.value
I get an error "-- @path XMLC=/XML2XMLproject/M2/XML.ecore
in
if e->notEmpty()
then
else
endif
in
if eltC->notEmpty()
then
eltC->first().value
else
endif;
in
if e->notEmpty()
then
else
endif
rule RootToRoot {
from
i: XMLS!Root
to
o : XMLC!Root (
name <- i.name,
comp:XMLC!Element(
from
i: XMLS!Element
to
o : XMLC!Element (
name <- i.name
from
i: XMLS!Attribute
to
name <- i.name,
value <- i.value
in
if e->notEmpty()
then
else
endif
in
if eltC->notEmpty()
then
eltC->first().value
else
endif;
in
if e->notEmpty()
then
else
endif
rule RootToRoot {
from
i: XMLS!Root
to
o : XMLC!Root (
name <- i.name,
comp:XMLC!Element(
from
i: XMLS!Element
to
o : XMLC!Element (
name <- i.name
from
i: XMLS!Attribute
to
name <- i.name,
value <- i.value
I get an error "org.eclipse.m2m.atl.engine.emfvm.VMException: Trying to register several rules as default for element org.eclipse.emf.ecore.impl.DynamicEObjectImpl@1a24699 (eClass: org.eclipse.emf.ecore.impl.EClassImpl@1b25736 (name: Root) (instanceClassName: null) (abstract: false, interface: false)) : RootToRoot and ElementToElement"
It works for you!!
Thank you.
Samar
| Re: XML2XML [message #1060255 is a reply to message #1060181] |
Thu, 23 May 2013 13:11  |
If you look to the XML metamodel you are using, I guess you will see that Root is inheriting from Element (which means that a Root element is also an Element element, that could be why you have your error).
Thus, in your ElementToElement rule, you have to add a filter to avoid such a Root element to be matched twice (i.e. also by the RootToRoot rule):
from
i: XMLS!Element (
not i.oclIsTypeOf(XMLS!Root)
Nantes - France
Current Time: Tue May 28 09:21:53 EDT 2013
Powered by FUDForum. Page generated in 0.02076 seconds
