Home » Modeling » TMF (Xtext) » Xtext 2.4 referencing UML
Xtext 2.4 referencing UML [message #1060115] Thu, 23 May 2013 03:44 Go to next message
Marc Z is currently offline Marc Z
I'm trying the reference UML elements in my DSL usign the following workflow:
Workflow {
    bean = StandaloneSetup {
    	scanClassPath = true
    	platformUri = "${runtimeProject}/.."
 	// The following two lines can be removed, if Xbase is not used.
    	registerGeneratedEPackage = "org.eclipse.xtext.xbase.XbasePackage"
    	registerGenModelFile = "platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel"
        registerGeneratedEPackage = "org.eclipse.emf.ecore.EcorePackage"
	registerGenModelFile = "platform:/resource/org.eclipse.emf.ecore/model/Ecore.genmodel"
        registerGeneratedEPackage = "org.eclipse.uml2.uml.UMLPackage"
        registerGenModelFile = "platform:/resource/org.eclipse.uml2.uml/model/UML.genmodel"
        registerGeneratedEPackage = "org.eclipse.emf.codegen.ecore.genmodel.GenModelPackage"
        registerGenModelFile = "platform:/resource/org.eclipse.emf.codegen.ecore/model/GenModel.genmodel"
        registerGeneratedEPackage = "org.eclipse.uml2.codegen.ecore.genmodel.GenModelPackage"
        registerGenModelFile = "platform:/resource/org.eclipse.uml2.codegen.ecore/model/GenModel.genmodel"
    component = DirectoryCleaner {
    	directory = "${runtimeProject}/src-gen"
    	directory = "${runtimeProject}.ui/src-gen"
    component = Generator {
    	pathRtProject = runtimeProject
    	pathUiProject = "${runtimeProject}.ui"
    	pathTestProject = "${runtimeProject}.tests"
    	projectNameRt = projectName
    	projectNameUi = "${projectName}.ui"
    	language = auto-inject {
    		uri = grammarURI
    		// Java API to access grammar elements (required by several other fragments)
    		fragment = grammarAccess.GrammarAccessFragment auto-inject {}
    		// generates Java API for the generated EPackages
    		fragment = ecore.EcoreGeneratorFragment auto-inject {
    		// referencedGenModels = "
    		//  platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel,
    		//  platform:/resource/org.eclipse.xtext.common.types/model/JavaVMTypes.genmodel
    		// the old serialization component
    		// fragment = parseTreeConstructor.ParseTreeConstructorFragment auto-inject {}
    		// serializer 2.0
    		fragment = serializer.SerializerFragment auto-inject {
    			generateStub = false
    		// a custom ResourceFactory for use with EMF
    		fragment = resourceFactory.ResourceFactoryFragment auto-inject {}
    		// The antlr parser generator fragment.
    		fragment = parser.antlr.XtextAntlrGeneratorFragment auto-inject {
    		//  options = {
    		//      backtrack = true
    		// Xtend-based API for validation
    		fragment = validation.ValidatorFragment auto-inject {
    		//    composedCheck = "org.eclipse.xtext.validation.ImportUriValidator"
    		//    composedCheck = "org.eclipse.xtext.validation.NamesAreUniqueValidator"
    		// old scoping and exporting API
    		// fragment = scoping.ImportURIScopingFragment auto-inject {}
    		// fragment = exporting.SimpleNamesFragment auto-inject {}
    		// scoping and exporting API
    		fragment = scoping.ImportNamespacesScopingFragment auto-inject {}
    		fragment = exporting.QualifiedNamesFragment auto-inject {}
    		fragment = builder.BuilderIntegrationFragment auto-inject {}
    		// generator API
    		fragment = generator.GeneratorFragment auto-inject {}
    		// formatter API
    		fragment = formatting.FormatterFragment auto-inject {}
    		// labeling API
    		fragment = labeling.LabelProviderFragment auto-inject {}
    		// outline API
    		fragment = outline.OutlineTreeProviderFragment auto-inject {}
    		fragment = outline.QuickOutlineFragment auto-inject {}
    		// quickfix API
    		fragment = quickfix.QuickfixProviderFragment auto-inject {}
    		// content assist API
    		fragment = contentAssist.ContentAssistFragment auto-inject {}
    		// generates a more lightweight Antlr parser and lexer tailored for content assist
    		fragment = parser.antlr.XtextAntlrUiGeneratorFragment auto-inject {}
    		// generates junit test support classes into Generator#pathTestProject
    		fragment = junit.Junit4Fragment auto-inject {}
    		// project wizard (optional)
    		// fragment = projectWizard.SimpleProjectWizardFragment auto-inject {
    		//      generatorProjectName = "${projectName}"
    		// rename refactoring
    		fragment = refactoring.RefactorElementNameFragment auto-inject {}
    		// provides the necessary bindings for java types integration
    		fragment = types.TypesGeneratorFragment auto-inject {}
    		// generates the required bindings only if the grammar inherits from Xbase
    		fragment = xbase.XbaseGeneratorFragment auto-inject {}
    		// provides a preference page for template proposals
    		fragment = templates.CodetemplatesGeneratorFragment auto-inject {}
    		// provides a compare view
    		fragment = compare.CompareFragment auto-inject {}
But running the workflow always results in the following error:
Caused by: org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri '.../uml2/2.2.0/GenModel' not found. (platform:/resource/org.eclipse.uml2.uml/model/UML.genmodel, 13, 32)
Dows anyone know how to fix this error?
Thx Marc
Re: Xtext 2.4 referencing UML [message #1060249 is a reply to message #1060115] Thu, 23 May 2013 12:57 Go to previous message
Have a look at
http://git.eclipse.org/c/mdt/org.eclipse.ocl.git/tree/examples/org.eclipse.ocl.examples.build/src/org/eclipse/ocl/examples/build/utilities/UMLGenModelSetup.java.
Ed Willink
On 23/05/2013 08:44, Marc Z wrote:
> workflow:
> Workflow {
> uri = grammarURI
> // fragment =
> // serializer 2.0
> auto-inject {}
> auto-inject {
> // options = {
> // backtrack = true
> // composedCheck =
> // composedCheck =
> auto-inject {}
> // generator API
> // formatter API
> // labeling API
> // outline API
> // quickfix API
> auto-inject {}
> auto-inject {
> auto-inject {}
> integration
> inherits from Xbase
> auto-inject {}
> Thx Marc
Previous Topic:How to get ecore and genmodel?
Next Topic:Error resolving cross references on resource
Current Time: Tue May 28 17:13:55 EDT 2013
Powered by FUDForum. Page generated in 0.02051 seconds
