| Re: Remove bottom padding from rectangle [message #1060247 is a reply to message #1059479] |
Thu, 23 May 2013 12:47  |
Thomas Beyer Messages: 55 Registered: February 2013 |
Member |
Hi Jack,
do you really need to wrap your label inside a rectangle?
You could just use a Label (no FigureDescriptor) for your attribute.
This way, there will be no additional space between the labels.
Is this an option?
Otherwise you would have to tweek the standard code, as the rectangle figures (to be precisely: its editpart-controllers and teh corresponding resizableeditpolicy) are implemented by default not to go below a predefined minimum-size, depending on the layout.
I could also help you with this approach.
Regards Thomas
FUDForum. Page generated in 0.01753 seconds
