Home » Modeling » QVT-OML » Stereotypes and multi-valued attributes(Can't get the value of a multi-valued attribute defined in a Stereotype)
Stereotypes and multi-valued attributes [message #1060191] Thu, 23 May 2013 08:59 Go to next message
Matteo M. is currently offline Matteo M.
Dear all,
I've defined a Stereotype, MyStereo, with a multi-valued attribute (1..*, Integer), mvAttrib. I've applied the Stereotype to an element in my model, myElem, and I've been able to set its multi-value (3,5,1) through Papyrus.
Now, In a QVTo transform, I want to get back these values. I tried with
myElem.getValue(MyStereo, "mvAttrib")
but it returns a Bag(OclAny)[1] element, where the sole value in the returned element is 3 (i.e., the first one I set for mvAttrib). How do I retrieve ALL the values in a multi-value attribute of a Stereotype?
Side question: As I said, I've been able to set the multi-value through Papyrus. How do I set it in QVTo? I tried with
myElem.setValue(MyStereo, "mvAttrib", Sequence{3,5,1})
but the interpreter complains about "Cannot find operation (setValue(Stereotype, String, Sequence(Integer))) for the type ..."
Thanks and best regards,
Matteo
Re: Stereotypes and multi-valued attributes [message #1060197 is a reply to message #1060191] Thu, 23 May 2013 09:06 Go to previous messageGo to next message
You assume that you have declared your'multi-value' myElem correctly. No
idea what a 'multi-value' is; I guess that you mean collection.
But since you haven't shared the declaration of myElem with us it is
difficult to comment.
You can save everyone a lot of time with a simple zipped project that
demonstrates your problem.
REgards
Ed Willink
On 23/05/2013 13:59, Matteo M. wrote:
> Dear all,
> through Papyrus.
> Matteo
Re: Stereotypes and multi-valued attributes [message #1060212 is a reply to message #1060197] Thu, 23 May 2013 10:24 Go to previous messageGo to next message
When I try to reply, I see this info:
File Attachments:	Allowed File Extensions: (unrestricted)
			Maximum File Size: 0KB
			Maximum Files Per Message: 0
So, it seems that I'm unable to send file attachments. I do have a test project that illustrates the problem. Should I send it to you (how/where?) so that you can send it to the forum? Other options?
Re: Stereotypes and multi-valued attributes [message #1060216 is a reply to message #1060212] Thu, 23 May 2013 10:42 Go to previous messageGo to next message
HI
I thought the limuits were only on the first five messages and you sent
more than that.
I find DropBox very useful.
Ed Willink
Re: Stereotypes and multi-valued attributes [message #1060224 is a reply to message #1060216] Thu, 23 May 2013 11:15 Go to previous messageGo to next message
This is the link:
https://www.dropbox.com/s/pu7c3mzd3ruz8ab/MyProjects.zip
Let me explain how you (or others) can reproduce the issue.
Please unzip MyProjects.zip. There are 2 projects:
- MyProjectSysML
- MyProjectM2M
In MyProjectSysML you'll find a profile (model.profile) that defines the Stereotype MyStereo with the multi-valued attribute mvAttrib (1..*, Integer (from UML standard types)). Then you'll find the source model (model) that contains a SysML block, myElem, stereotyped as MyStereo. I set the values of mvAttrib of myElem through the Papyrus UI. I gave the values 3,5,1. Finally, you'll find an empty model, that is the target of the M2M transform.
In MyProjectM2M you'll find the QVTo transform (NewTransformation). Please set up your config so as MyProjectSysML/model.uml is your source model and MyProjectSysML/emptyModel.uml is your destination model. Then debug the QVTo transform (only debug the transform or you won't see anything; this is only a trivial example). You'll see that at line 11, the instruction
var mvAttribValues := myElem.getValue(MyStereo, "mvAttrib");
will put only the Integer value 3 in mvAttribValues and not the sequence (?) 3,5,1. How do I get all the values (3,5,1) of mvAttrib?
Matteo
Re: Stereotypes and multi-valued attributes [message #1060231 is a reply to message #1060224] Thu, 23 May 2013 11:53 Go to previous messageGo to next message
As I suspected, it is the declaration of myElem that is at fault.
var myElem : Class := MyModel.ownedElement->select(e |
e.oclIsKindOf(Class))->oclAsType(Class)![name = "myElem"];
I'm not a fan of ! [] cuteness so I had to look them up and the
documentation is pretty thin.
Your code does not match the
list->prop![startswith("_")]) ; // calling collectselectOne(i;res=
i.prop | not res.startswith("_"))
template, so maybe it's illegal; who knows. Using common sense one might
like it to be
.ownedElement
->select(e | e.oclIsKindOf(Class))
->oclAsType(Class)
->collectselectOne(not (name = "myElem"))
which might mean myElem is a random Class not named myElem. Not what you
wanted.
I find the pure OCL.
e.oclIsKindOf(Class))->oclAsType(Class)->any(name = "myElem");
clearer. As from Indigo you can do
MyModel.ownedElement->selectByKind(Class)->any(name = "myElem");
Ed Willink
On 23/05/2013 16:15, Matteo M. wrote:
> This is the link:
> - MyProjectSysML
> - MyProjectM2M
> Matteo
Re: Stereotypes and multi-valued attributes [message #1060257 is a reply to message #1060231] Thu, 23 May 2013 13:13 Go to previous messageGo to next message
Reading more carefully; the declaration and pseudo code of
collectselectOne clearly returns a Sequence, so you should have a syntax
error when assigning to a Class. Please raise a Bugzilla.
Ed Willink
On 23/05/2013 16:53, Ed Willink wrote:
> Hi
> might like it to be
> .ownedElement
> ->oclAsType(Class)
> you wanted.
> Regards
> Ed Willink
>> This is the link:
>> - MyProjectSysML
>> - MyProjectM2M
>> Matteo
Re: Stereotypes and multi-valued attributes [message #1060364 is a reply to message #1060231] Fri, 24 May 2013 06:05 Go to previous messageGo to next message
I admit I have not completely understood your complaints about the use of the ![] operator. However, from your reply it seems to me that you are suggesting that simply changing to
var myElem : Class := MyModel.ownedElement->selectByKind(Class)->any(name = "myElem");
does the job. I tried it, but it has not worked. I still get only one integer value (3) in mvAttribValue after the execution of:
Does the code you suggest work for you?
Anyway, I also tried this one:
var mvAttribValues : Sequence(Integer) := myElem.getValue(MyStereo, "mvAttrib");
but the interpreter says that "Type mismatch: can not convert from 'oclstdlib::OclAny' to 'NewTransformation::Sequence(Integer)' type"
Then I came across to this one:
http://www.eclipse.org/forums/index.php/mv/msg/440627/987427/#msg_987427
that it seems very similar to the problem I'm dealing with. So I tried to change to
var mvAttribValues := myElem.getValue(MyStereo, "mvAttrib").oclAsSet()->flatten()->selectByKind(Integer)
but it does not work for me (I get a Collection with only one integer value (3)). I tried with the latest QVTo (RC1 in Kepler). Nothing.
Maybe I have wrongly defined my SysML profile or my SysML model? I can't believe that there is no an easy way to get a collection of integers from an attribute of a stereotyped model element, when that attribute has type Integer [1..*] (so it should be straightforward to map its values to a collection).
Again, the link to the example project is this one:
Any concrete suggestion in solving my issue would be greatly appreciated!
Thank you in advance!
Matteo
Re: Stereotypes and multi-valued attributes [message #1060527 is a reply to message #1060364] Sun, 26 May 2013 04:48 Go to previous message
Sergey Boyko is currently offline Sergey Boyko
Hi Matteo,
The problem is that the return type of method .getValue() is java.lang.Object which is mapped to OclAny type.
QVTo is based on OCL 2.0 implementation which states that:
"All types in the UML model and the primitive types in the OCL standard library comply with the type OclAny.
Conceptually, OclAny behaves as a supertype for all the types except for the OCL pre-defined collection types."
Despite the fact that .getValue() returns List object for multivalued attribute OCL implementation internally coerces this List into single object (specifically OCL implementation fetches and returns the first element from the list).
More over due to specification it is impossible to convert OclAny type to Collection type (by means of .oclAsType() call).
Btw, current OCL 2.3.1 specification states that:
"All types in the UML model and the primitive and collection types in the OCL standard library conforms to the type
OclAny. Conceptually, OclAny behaves as a supertype for all the types."
However OCL implementation which is used by QVTo doesn't support that.
There are two ways to overcome the problem.
1. Provide Java blackbox library methods .getMultivalue() / .setMultivalue which operate with collections.
2. Use extended syntax of .getValue() / .setValue() that is supported by UML.
For example, to fetch second element from the multivalued attribute one should write the following call:
var v : Integer := myElem.getValue(MyStereo, "mvAttrib[1]").oclAsType(Integer);
For example, to set third element to the multivalued attribute one should write the following call:
myElem.setValue(MyStereo, "mvAttrib[2]", 11);
or
myElem.setValue(MyStereo, "mvAttrib[2]", "11");
UML also supports syntax for association navigation by means of '::' separator in attribute name. For example (in case the 'mvAttrib' is of type of Classifier):
myElem.setValue(MyStereo, "mvAttrib[2]::subAttrib[1]", 11);
Sergey.
Previous Topic:Generalization relationship between stereotypes
Next Topic:how to use two target sources?
Current Time: Tue May 28 20:51:17 EDT 2013
Powered by FUDForum. Page generated in 0.01823 seconds
