| Re: convert XMI file TO Java class [message #1060134 is a reply to message #1060128] |
Thu, 23 May 2013 05:22   |
Hugo Bruneliere Messages: 469 Registered: July 2009 |
What do you mean by "converting an XMI file to a Java class"?
Your XMI file is actually a model that conforms to a metamodel (in Ecore): first, what is this metamodel?
Then, what (conceptual) mapping do you want to implement between this metamodel and Java?
Hugo Bruneliere - R&D Engineer
AtlanMod research team (Inria, EMN & LINA)
Ecole des Mines de Nantes
Nantes - France
| Re: convert XMI file TO Java class [message #1060153 is a reply to message #1060140] |
Thu, 23 May 2013 06:54  |
So you could for instance build a model transformation from Jade to Java (using the Java metamodel as provided by the MoDisco project, cf. the reference documentation of this project for more info) and then, from the produced Java model, generate the corresponding code (using the Java generator as also provided by the MoDisco project).
Nantes - France
FUDForum. Page generated in 0.01587 seconds
