Home » Modeling » EMF » [CDO] Clearing a CDOResource content which has a Proxy object
[CDO] Clearing a CDOResource content which has a Proxy object [message #1059281] Fri, 17 May 2013 06:46 Go to next message
Christophe Bouhier is currently offline Christophe Bouhier
I have a CDOResource, which has an object in it's content looking like
this: (Copy paste from Variable View).
eObject $Proxy23 (id=5790)
'eObject' referenced from:
h org.eclipse.emf.cdo.view.CDOStaleReferencePolicy$2$1 (id=5792)
'h' referenced from:
this$1 org.eclipse.emf.cdo.view.CDOStaleReferencePolicy$2 (id=333)
val$source
com.netxforge.netxstudio.scheduling.impl.JobRunContainerImpl (id=5795)
val$target
org.eclipse.emf.cdo.internal.common.id.CDOIDObjectLongImpl (id=5796)
val$type org.eclipse.emf.ecore.impl.EClassImpl (id=338)
So apparently the referenced object was not resolved from the target.
(JobRunContainer).
How can I detect a stale reference? I have tried using
CDOUtil.isStaleObject(..) but it's negative on the referenced object. (I
can actually get the object with an exception).
But when I clear the contents, I get an exception:
I clean the list like this: (As you might notice, I call retainAll()
which calls indexOf(..)
I can get the same exception with contents.indexOf(Object).
| QuartzScheduler_Worker-2 | 2013-05-17 12:39:08.575 |
com.netxforge.netxstudio.server.job | /trace.jobs |
com.netxforge.netxstudio.server.job.NetxForgeJob | execute | 127 | Error
instantiating job: class
com.netxforge.netxstudio.scheduling.impl.MetricSourceJobImpl |
org.eclipse.emf.cdo.util.ObjectNotFoundException: Object OID21459772 not
found
org.eclipse.emf.cdo.view.CDOStaleReferencePolicy$2$1.invoke(CDOStaleReferencePolicy.java:101)
at $Proxy23.equals(Unknown Source)
at java.util.ArrayList.indexOf(ArrayList.java:269)
at java.util.ArrayList.contains(ArrayList.java:252)
org.eclipse.emf.common.util.DelegatingEList.retainAll(DelegatingEList.java:579)
com.netxforge.netxstudio.server.job.NetxForgeJob.addAndTruncate(NetxForgeJob.java:236)
com.netxforge.netxstudio.server.job.NetxForgeJob.createWorkFlowMonitor(NetxForgeJob.java:146)
com.netxforge.netxstudio.server.job.NetxForgeJob.execute(NetxForgeJob.java:115)
at org.quartz.core.JobRunShell.run(JobRunShell.java:206)
org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:548)
Thanks! Christophe
Re: [CDO] Clearing a CDOResource content which has a Proxy object [message #1059282 is a reply to message #1059281] Fri, 17 May 2013 06:47 Go to previous messageGo to next message
On 17-05-13 12:46, Christophe Bouhier wrote:
> (id=333)
> val$source
> val$target
> (JobRunContainer).
Oops, that should be "without an exception"
> found
> at
> at
> at
> at
> at
> at
> Thanks! Christophe
Re: [CDO] Clearing a CDOResource content which has a Proxy object [message #1059359 is a reply to message #1059281] Fri, 17 May 2013 12:11 Go to previous messageGo to next message
Eike Stepper is currently offline Eike Stepper
Am 17.05.2013 12:46, schrieb Christophe Bouhier:
> I have a CDOResource, which has an object in it's content looking like this: (Copy paste from Variable View).
> val$source com.netxforge.netxstudio.scheduling.impl.JobRunContainerImpl (id=5795)
> val$target org.eclipse.emf.cdo.internal.common.id.CDOIDObjectLongImpl (id=5796)
> So apparently the referenced object was not resolved from the target. (JobRunContainer).
> CDOUtil.isStaleObject(..) but it's negative on the referenced object. (I can actually get the object with an exception).
What does CDOUtil.isStaleObject(..) return for that object (the one that you can get without an exception)? Can you
provide me with a small test case to reproduce it?
You can also compare with Bugzilla_279982_Test.testBugzilla_279982_Single().
> I clean the list like this: (As you might notice, I call retainAll() which calls indexOf(..)
> | QuartzScheduler_Worker-2 | 2013-05-17 12:39:08.575 | com.netxforge.netxstudio.server.job | /trace.jobs |
> com.netxforge.netxstudio.server.job.NetxForgeJob | execute | 127 | Error instantiating job: class
> com.netxforge.netxstudio.scheduling.impl.MetricSourceJobImpl | org.eclipse.emf.cdo.util.ObjectNotFoundException:
> Object OID21459772 not found
> at org.eclipse.emf.cdo.view.CDOStaleReferencePolicy$2$1.invoke(CDOStaleReferencePolicy.java:101)
Hm, we could let the proxy handle calls to equals() such that "arg0 == this", instead of throwing an
ObjectNotFoundException. Please submit an enhancement request.
Cheers
/Eike
http://www.esc-net.de
> at org.eclipse.emf.common.util.DelegatingEList.retainAll(DelegatingEList.java:579)
> at com.netxforge.netxstudio.server.job.NetxForgeJob.addAndTruncate(NetxForgeJob.java:236)
> at com.netxforge.netxstudio.server.job.NetxForgeJob.createWorkFlowMonitor(NetxForgeJob.java:146)
> at com.netxforge.netxstudio.server.job.NetxForgeJob.execute(NetxForgeJob.java:115)
> at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:548)
> Thanks! Christophe
Re: [CDO] Clearing a CDOResource content which has a Proxy object [message #1059771 is a reply to message #1059359] Tue, 21 May 2013 10:36 Go to previous messageGo to next message
>> (id=333)
>> val$source
>> val$target
>> (JobRunContainer).
> you can get without an exception)? Can you provide me with a small test
Thanks Eike, will check this test case.
>> not found
>> at
> this", instead of throwing an ObjectNotFoundException. Please submit an
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
>> at
>> at
>> at
>> at
>> at
>> Thanks! Christophe
Re: [CDO] Clearing a CDOResource content which has a Proxy object [message #1060102 is a reply to message #1059771] Thu, 23 May 2013 02:54 Go to previous messageGo to next message
Leila A is currently offline Leila A
Dear Christophe,
Sorry for posting this question here.
I need to manage palette in papyrus programmatically when user is working on the diagram editor. When I select an element in the diagram editor, I need to refresh the palette. So I want to be able to add/remove some entries or set them as visible or invisible on the palette.
I found your reply to Dave posted in July 2009 about changing palette icons. You mentioned that its possible to access to paletteRoot through the editor: XXXDiagramEditor.getEditDomain().getpaletteViewer().getpaletteRoot()
Is the paletteRoot what I need for this case?
I traced the code and I guess the XXXDiagramEditor is UMLDiagramEditor. But the problem is that I don't know how to access to the UMLDiagramEditor:( can you please guide me?
Thanks and regards,
Leila
Christophe Bouhier wrote on Tue, 21 May 2013 10:36
>> (id=333)
>> val$source
>> val$target
>> (JobRunContainer).
>> not found
>> at
> Cheers
> /Eike
>> at
>> at
>> at
>> at
>> at
>> Thanks! Christophe
Re: [CDO] Clearing a CDOResource content which has a Proxy object [message #1060127 is a reply to message #1060102] Thu, 23 May 2013 04:27 Go to previous messageGo to next message
Am 23.05.2013 08:54, schrieb Leila A:
> Dear Christophe,
> Is the paletteRoot what I need for this case? I traced the code and I guess the XXXDiagramEditor is UMLDiagramEditor.
How's that related to CDO?
Cheers
/Eike
> Thanks and regards,
> Leila
>> >> Hi,
>> >> (id=333)
>> >> val$source
>> >> val$target
>> >> (JobRunContainer).
>> >> not found
>> >> at
>> > Cheers
>> > /Eike
>> >> at
>> >> at
>> >> at
>> >> at
>> >> at
>> >> Thanks! Christophe
Re: [CDO] Clearing a CDOResource content which has a Proxy object [message #1060136 is a reply to message #1060102] Thu, 23 May 2013 05:28 Go to previous message
On 23-05-13 08:54, Leila A wrote:
> Dear Christophe,
I think it's better to mail them directly, if you need someone's
specific attention. Many people watching this forum will frown reading a
question about GMF/GEF here. Please mail me directly or on the GMF
forum, I will try to find the answer for you.
> the editor:
> guide me?
> Thanks and regards,
> Leila
>> >> Hi,
>> (id=5792)
>> >> (id=333)
>> >> val$source
>> >> val$target
>> >> (JobRunContainer).
>> that
>> >> not found
>> >> at
>> > Cheers
>> > /Eike
>> >> at
>> >> at
>> >> at
>> >> at
>> >> at
>> >> Thanks! Christophe
Previous Topic:Customize EMF Enums
Next Topic:Trying to reference EClassifier in my model
Current Time: Tue May 28 11:36:31 EDT 2013
Powered by FUDForum. Page generated in 0.01772 seconds
