Home » Modeling » ATL » Plugin ATL
| Plugin ATL [message #1059551] |
Mon, 20 May 2013 08:32  |
ransou RMG Messages: 15 Registered: February 2013 |
Junior Member |
Hi everybody,
I created an ATL PROJECT which runs successfully.Now I would like to do the transformation by using the a project which its type is "Plugin ATL".
I created it and and I chose the ATL launch configuration the one related to the first ATL project.The CREATION of the ATL plugin is done sccessfully.My problem now is in tha java class generated by the plugin.it is like this:
* Copyright (c) 2010, 2012 Obeo.
* All rights reserved. This program and the accompanying materials
* are made available under the terms of the Eclipse Public License v1.0
* which accompanies this distribution, and is available at
* http://www.eclipse.org/legal/epl-v10.html
* Contributors:
* Obeo - initial API and implementation
package org.eclipse.m2m.atl.Project.files;
import java.io.IOException;
import java.io.InputStream;
import java.net.URL;
import java.util.HashMap;
import java.util.Map;
import java.util.Properties;
import java.util.Map.Entry;
import org.eclipse.core.runtime.FileLocator;
import org.eclipse.core.runtime.IProgressMonitor;
import org.eclipse.core.runtime.NullProgressMonitor;
import org.eclipse.core.runtime.Path;
import org.eclipse.core.runtime.Platform;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.xmi.impl.EcoreResourceFactoryImpl;
import org.eclipse.m2m.atl.common.ATLExecutionException;
import org.eclipse.m2m.atl.core.ATLCoreException;
import org.eclipse.m2m.atl.core.IExtractor;
import org.eclipse.m2m.atl.core.IInjector;
import org.eclipse.m2m.atl.core.IModel;
import org.eclipse.m2m.atl.core.IReferenceModel;
import org.eclipse.m2m.atl.core.ModelFactory;
import org.eclipse.m2m.atl.core.emf.EMFExtractor;
import org.eclipse.m2m.atl.core.emf.EMFInjector;
import org.eclipse.m2m.atl.core.emf.EMFModelFactory;
import org.eclipse.m2m.atl.core.launch.ILauncher;
import org.eclipse.m2m.atl.engine.emfvm.launch.EMFVMLauncher;
* Entry point of the 'Tpf3' transformation module.
public class Families2Persons {
* The property file. Stores module list, the metamodel and library locations.
* @generated
private Properties properties;
* The IN model.
* @generated
protected IModel inModel;
* The OUT model.
* @generated
protected IModel outModel;
* The main method.
* @param args
* are the arguments
* @generated
try {
// if (args.length < 2) {
// System.out.println("Arguments not valid : {IN_model_path, OUT_model_path}.");
//} else {
Families2Persons runner = new Families2Persons();
//runner.loadModels(args[0]);
runner.loadModels("sample-Families.xmi");
runner.doFamilies2Persons(new NullProgressMonitor());
//runner.saveModels(args[1]);
runner.saveModels("sample-Persons.xmi");
} catch (ATLCoreException e) {
e.printStackTrace();
} catch (IOException e) {
} catch (ATLExecutionException e) {
* Constructor.
* @generated
public Families2Persons() throws IOException {
properties = new Properties();
properties.load(getFileURL("Families2Persons.properties").openStream());
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap().put("ecore", new EcoreResourceFactoryImpl());
//System.out.println(properties);
* Load the input and input/output models, initialize output models.
* @param inModelPath
* the IN model path
* @throws ATLCoreException
* if a problem occurs while loading models
* @generated
public void loadModels(String inModelPath) throws ATLCoreException {
ModelFactory factory = new EMFModelFactory();
IInjector injector = new EMFInjector();
IReferenceModel sourceMetamodel = factory.newReferenceModel();
injector.inject(sourceMetamodel, getMetamodelUri("Families.ecore"));
IReferenceModel targetMetamodel = factory.newReferenceModel();
injector.inject(targetMetamodel, getMetamodelUri("Persons.ecore"));
this.inModel = factory.newModel(sourceMetamodel);
injector.inject(inModel, inModelPath);
this.outModel = factory.newModel(targetMetamodel);
* Save the output and input/output models.
* @param outModelPath
* the OUT model path
* if a problem occurs while saving models
* @generated
public void saveModels(String outModelPath) throws ATLCoreException {
IExtractor extractor = new EMFExtractor();
extractor.extract(outModel, "/org.eclipse.m2m.atl.Project/sample-Persons.xmi");
* Transform the models.
* @param monitor
* the progress monitor
* if an error occurs during models handling
* @throws IOException
* if a module cannot be read
* @throws ATLExecutionException
* if an error occurs during the execution
* @generated
public Object doFamilies2Persons(IProgressMonitor monitor) throws ATLCoreException, IOException, ATLExecutionException {
ILauncher launcher = new EMFVMLauncher();
Map<String, Object> launcherOptions = getOptions();
launcher.initialize(launcherOptions);
launcher.addInModel(inModel, "IN", "source");
launcher.addOutModel(outModel, "OUT", "target");
return launcher.launch("run", monitor, launcherOptions, (Object[]) getModulesList());
* Returns an Array of the module input streams, parameterized by the
* property file.
* @return an Array of the module input streams
* @generated
protected InputStream[] getModulesList() throws IOException {
InputStream[] modules = null;
String modulesList = properties.getProperty("Families2Persons.modules");
if (modulesList != null) {
String[] moduleNames = modulesList.split(",");
modules = new InputStream[moduleNames.length];
for (int i = 0; i < moduleNames.length; i++) {
String asmModulePath = new Path(moduleNames[i].trim()).removeFileExtension().addFileExtension("asm").toString();
modules[i] = getFileURL(asmModulePath).openStream();
return modules;
* Returns the URI of the given metamodel, parameterized from the property file.
* @param metamodelName
* the metamodel name
* @return the metamodel URI
* @generated
protected String getMetamodelUri(String metamodelName) {
return properties.getProperty("Families2Persons.metamodels." + metamodelName);
* Returns the file name of the given library, parameterized from the property file.
* @param libraryName
* the library name
* @return the library file name
* @generated
protected InputStream getLibraryAsStream(String libraryName) throws IOException {
return getFileURL(properties.getProperty("Families2Persons.libraries." + libraryName)).openStream();
* Returns the options map, parameterized from the property file.
* @return the options map
* @generated
protected Map<String, Object> getOptions() {
Map<String, Object> options = new HashMap<String, Object>();
for (Entry<Object, Object> entry : properties.entrySet()) {
if (entry.getKey().toString().startsWith("Families2Persons.options.")) {
options.put(entry.getKey().toString().replaceFirst("Families2Persons.options.", ""),
entry.getValue().toString());
return options;
* Finds the file in the plug-in. Returns the file URL.
* @param fileName
* the file name
* @return the file URL
* if the file doesn't exist
* @generated
protected static URL getFileURL(String fileName) throws IOException {
final URL fileURL;
if (isEclipseRunning()) {
URL resourceURL = Families2Persons.class.getResource(fileName);
if (resourceURL != null) {
fileURL = FileLocator.toFileURL(resourceURL);
} else {
fileURL = null;
} else {
fileURL = Families2Persons.class.getResource(fileName);
if (fileURL == null) {
throw new IOException("'" + fileName + "' not found");
} else {
return fileURL;
* Tests if eclipse is running.
* @return <code>true</code> if eclipse is running
* @generated
public static boolean isEclipseRunning() {
try {
return Platform.isRunning();
} catch (Throwable exception) {
// Assume that we aren't running.
return false;
The console seems like this:
Exception in thread "main" java.lang.NullPointerException
at org.eclipse.m2m.atl.core.emf.EMFInjector.inject(EMFInjector.java:58)
at org.eclipse.m2m.atl.core.emf.EMFInjector.inject(EMFInjector.java:84)
at org.eclipse.m2m.atl.Project.files.Families2Persons.loadModels(Families2Persons.java:118)
at org.eclipse.m2m.atl.Project.files.Families2Persons.main(Families2Persons.java:78)
My question is where can I place the metamodels(in format "ecore")and the models (in format .xmi).I mean their path because I place them in the plugin.What are my errors.
Please help me and I will be thankful very much
| Re: Plugin ATL [message #1059691 is a reply to message #1059610] |
Tue, 21 May 2013 04:58   |
Hugo Bruneliere Messages: 469 Registered: July 2009 |
There is no specific place to put your models and metamodels, it's up to you to decide.
According to your choice, the paths of the input/output metamodels can be set via the generated ".properties" file.
The paths of the input/output models are determined when calling to the generated loadModels and saveModels methods.
Hugo Bruneliere - R&D Engineer
AtlanMod research team (Inria, EMN & LINA)
Ecole des Mines de Nantes
Nantes - France
| Re: Plugin ATL [message #1059716 is a reply to message #1059691] |
Tue, 21 May 2013 06:43   |
Junior Member |
Thank you but the action of loading doesn't work.I place my models "sample-Families.xmi" which is not empty and "sample-Persons.xmi" which is empty in the same project "org.eclipse.m2m.atl.Families2Persons".
* Contributors:
package org.eclipse.m2m.atl.Families2Persons.files;
* Entry point of the 'Families2Persons' transformation module.
* @generated
* The IN model.
* @generated
* The OUT model.
* @generated
* The main method.
* @param args
* are the arguments
* @generated
try {
//if (args.length < 2) {
//} else {
//System.out.println("bj");
//System.out.println("xx");
* Constructor.
* @generated
//System.out.println("Bsr");
* the IN model path
* @generated
IReferenceModel familiesMetamodel = factory.newReferenceModel();
injector.inject(familiesMetamodel, getMetamodelUri("families"));
IReferenceModel personsMetamodel = factory.newReferenceModel();
injector.inject(personsMetamodel, getMetamodelUri("persons"));
this.inModel = factory.newModel(familiesMetamodel);
injector.inject(inModel,inModelPath);
this.outModel = factory.newModel(personsMetamodel);
* @generated
extractor.extract(outModel,outModelPath);
* @param monitor
* @generated
launcher.addInModel(inModel, "IN", "Families");
launcher.addOutModel(outModel, "OUT", "Persons");
* property file.
* @generated
return modules;
* @generated
* the library name
* @generated
* @generated
return options;
* @param fileName
* the file name
* @generated
final URL fileURL;
} else {
fileURL = null;
} else {
} else {
return fileURL;
* @generated
try {
return false;
the file of Families2Persons.properties seems like this:
# Families2Persons properties
# ATL modules: if several, by order of superimposition (the latter ones overrides the former ones)
Families2Persons.modules = Families2Persons.atl
# Metamodels paths or nsUris
Families2Persons.metamodels.Families = /Families2Persons/Families.ecore
Families2Persons.metamodels.Persons = /Families2Persons/Persons.ecore
# Libraries paths
# ATL Launching options
==>I need to find a solution the loading of models doesn't work.Can body tell me how can I do to solve the problem of loading.My program doesn't work and the console seems like this:
at org.eclipse.m2m.atl.Families2Persons.files.Families2Persons.loadModels(Families2Persons.java:118)
at org.eclipse.m2m.atl.Families2Persons.files.Families2Persons.main(Families2Persons.java:78)
| Re: Plugin ATL [message #1059722 is a reply to message #1059716] |
Tue, 21 May 2013 07:35   |
You don't need to create manually any Persons model as it is going to be produced by the transformation (what you have to provide is just a String expressing the selected path).
Concerning the metamodels and input model, you have to check that the provided paths/URIs are actually correct (and that the corresponding IDs are right in the properties file).
If everything is set correctly, then it should work properly.
Nantes - France
| Re: Plugin ATL [message #1059753 is a reply to message #1059725] |
Tue, 21 May 2013 10:03   |
As written in the generated code, you have to provide the input model path when calling to the loadModels method.
* the IN model path
* @generated
Nantes - France
Current Time: Tue May 28 09:22:49 EDT 2013
Powered by FUDForum. Page generated in 0.03740 seconds
