Home » Modeling » TMF (Xtext) » Getting the root node from a resource
Getting the root node from a resource [message #1059808] Tue, 21 May 2013 13:11 Go to next message
Erick Fonseca is currently offline Erick Fonseca
Is there a specific way to get the root node from a Resource? Currently I'm doing
resource.getContents().get(0)
But I feel it's weird to get the whole content list if I just want the root.
Re: Getting the root node from a resource [message #1059878 is a reply to message #1059808] Wed, 22 May 2013 01:14 Go to previous messageGo to next message
Henrik Lindberg is currently offline Henrik Lindberg
> I'm doing
> root.
You are doing it right.
A Resource is just more general than the use case of containing a parse
result.
- henrik
Re: Getting the root node from a resource [message #1059882 is a reply to message #1059808] Wed, 22 May 2013 01:41 Go to previous messageGo to next message
You're probably also doing
(MyRoot)resource.getContents().get(0)
which means that the user gets to see confusing stack traces for the
following errors
Resource is empty
Resource is multi-rooted
Resource doesn't contain MyRoot
usually resulting from a file name typo, but sometimes through
application defects.
I've taken to coding at least
for (EObject eObject : resource.getContents()) {
if (eObject instanceof MyRoot) {
doSomethingWith((MyRoot)eObject);
else {
some error
Ed Willink
> Currently I'm doing
> root.
Re: Getting the root node from a resource [message #1060039 is a reply to message #1059882] Wed, 22 May 2013 11:20 Go to previous messageGo to next message
Hallvard Traetteberg is currently offline Hallvard Traetteberg
> following errors
> Resource is empty
> else {
> some error
Yes, this is in general a lot better, since with Xtext-based DSLs it is
common to derive other models, and your particular root may not always
be the first element in such a case. I wish EcoreUtil had a method
<T> T getRoot(Class<T> clazz, boolean throwError) that did this, so it
was easy for everybody to start using this coding style.
Hallvard
Re: Getting the root node from a resource [message #1060055 is a reply to message #1060039] Wed, 22 May 2013 13:49 Go to previous message
Thank you for the insights. I will perform this check.
Previous Topic:Write new resource description very slow
Next Topic:How to get ecore and genmodel?
Current Time: Tue May 28 17:15:03 EDT 2013
Powered by FUDForum. Page generated in 0.01542 seconds
