| Why does ant not compile [message #1060038] |
Wed, 22 May 2013 11:23 |
Steve Howerton Messages: 5 Registered: April 2013 |
Junior Member |
I just starting building projects with and and eclipse ide. everything I try to import does not compile. I have added jar files to the lib or eclipse and the program runs in eclipse fine.
Why does ant not compile and build the project? How would I begin to fix the compile errors listed?
thanks
compile:
[echo] "
[echo]
[echo] ================================================
[echo] COMPILE
[echo]
[echo] "
[echo] C:\Users\Steves\Documents\ceyesumma\java_cache\my_projects\ecli
pse\com.cisumma.build.ant.first\target_com.cisumma.build.ant.first\com.cisu
mma.build.ant.first\src
mma.build.ant.first\build
[javac] C:\Users\Steves\Documents\ceyesumma\java_cache\my_projects\ecli
mma.build.ant.first\build.xml:120: warning: 'includeantruntime' was not set
, defaulting to build.sysclasspath=last; set to false for repeatable builds
[javac] Compiling 8 source files to C:\Users\Steves\Documents\ceyesumma
\java_cache\my_projects\eclipse\com.cisumma.build.ant.first\target_com.cisu
mma.build.ant.first\com.cisumma.build.ant.first\build\classes
mma.build.ant.first\src\model\Bar.java:3: error: package org.apache.log4j d
oes not exist
[javac] import org.apache.log4j.Logger;
[javac] ^
mma.build.ant.first\src\model\Bar.java:6: error: cannot find symbol
[javac] public static Logger logger = Logger.getLogger(Bar.class);
[javac] ^
[javac] symbol: class Logger
[javac] location: class Bar
mma.build.ant.first\src\model\Main.java:11: error: package org.apache.log4j
does not exist
[javac] ^
mma.build.ant.first\src\model\Main.java:12: error: package org.apache.log4j
does not exist
[javac] import org.apache.log4j.BasicConfigurator;
[javac] ^
mma.build.ant.first\src\model\Main.java:14: error: package com.toedter.cale
ndar does not exist
[javac] import com.toedter.calendar.JCalendar;
[javac] ^
mma.build.ant.first\src\model\Main.java:20: error: cannot find symbol
[javac] public static Logger logger = Logger.getLogger(Main.class);
[javac] ^
[javac] location: class Main
[javac] ^
[javac] symbol: variable Logger
[javac] ^
mma.build.ant.first\src\model\Main.java:30: error: cannot find symbol
[javac] BasicConfigurator.configure();
[javac] ^
[javac] symbol: variable BasicConfigurator
mma.build.ant.first\src\model\Main.java:53: error: cannot find symbol
[javac] JCalendar myJCalendar = new JCalendar();
[javac] ^
[javac] symbol: class JCalendar
[javac] ^
[javac] 11 errors
BUILD FAILED
C:\Users\Steves\Documents\ceyesumma\java_cache\my_projects\eclipse\com.cisu
mma.build.ant.first\target_com.cisumma.build.ant.first\com.cisumma.build.an
t.first\build.xml:120: Compile failed; see the compiler error output for de
tails.
Total time: 2 seconds
C:\ant\apache-ant-1.8.1\bin>
FUDForum. Page generated in 0.01724 seconds
