| Accessing an external Java class from JvmModelInferrer [message #1059861] |
Tue, 21 May 2013 22:17  |
Joey Mink Messages: 86 Registered: July 2009 Location: Centreville, VA, USA |
Member |
Hi all,
I've finally gotten the chance to write a grammar that extends Xbase. Yay! I've had a blast seeing Java classes created from my DSL, but I've encountered a problem I can't seem to get around.
As is customary, I created a separate bundle, com.joeymink.norm.lib, which has interfaces and classes that I hope to access from my NormJvmModelInferrer. I've added that bundle as a dependency of com.joeymink.norm (my DSL project/plug-in), and I have the following code (shortened for convenience):
class NormJvmModelInferrer extends AbstractModelInferrer {
@Inject extension JvmTypesBuilder
@Inject extension IQualifiedNameProvider
def dispatch void infer(NormFile normFile, IJvmDeclaredTypeAcceptor acceptor, boolean isPreIndexingPhase) {
if (normFile.normalizations != null) {
for (norm : normFile.normalizations)
inferNorm(acceptor, norm)
def protected inferNorm(IJvmDeclaredTypeAcceptor acceptor, Normalization norm) {
acceptor.accept(norm.toClass(norm.fullyQualifiedName)).initializeLater [
// Fields:
members += norm.toField("input_", newTypeRef(norm, 'com.joeymink.norm.lib.INormInput'))
members += norm.toField("output_", newTypeRef(norm, 'com.joeymink.norm.lib.INormOutput'))
The members += ... lines above create members of type Object instead of type INormInput/INormOutput. I can't seem to figure out why. When I debug it the newTypeRef calls return null. I don't fully understand the type provider API being used, but I see that the JdtTypeProvider is unable to find the type, com.joeymink.norm.lib.INormInput.
I wonder if there's a fundamental step or configuration I'm missing to make these externally-defined Java classes accessible to my DSL (JvmModelInferrer). Any thoughts?
| Re: Accessing an external Java class from JvmModelInferrer [message #1059869 is a reply to message #1059861] |
Tue, 21 May 2013 23:40   |
Ed Merks Messages: 24570 Registered: July 2009 |
Joey,
Is the library for these classes in the dependencies of the project that
contains the instance of the DSL resource?
On 22/05/2013 4:17 AM, Joey Mink wrote:
> Hi all,
> // Fields:
FUDForum. Page generated in 0.01670 seconds
