| Extension point & stereotype & pallete [message #1059860] |
Tue, 21 May 2013 20:51  |
Noelia as Messages: 13 Registered: June 2012 |
Junior Member |
I have created several prefiles for different elements, and I have created custom palettes with stereotype of these profiles, the problem is that for the element called extension point when i create a palette with stereotypes, these are not actually applied in the use case diagram, although the element is drawn .. Does anyone know if in this respect there is a problem with the element called extension point?
Thanks. Noelia.
FUDForum. Page generated in 0.01561 seconds
