Home » Modeling » EMF » Customize EMF Enums
Customize EMF Enums [message #1059785] Tue, 21 May 2013 11:19 Go to next message
Sir Wayne is currently offline Sir Wayne
how can i customize a EMF Enum. I want to use another object in the value textfield (properties view), but the textfield only accepted int values.
Generated Code
public enum EnumTest implements Enumerator
	TEST(0, "Test", "Test"), //$NON-NLS-1$ //$NON-NLS-2$
But i want to generate such code:
	TEST(AnotherClass.INTEGER_VALUE, "Test", "Test"), //$NON-NLS-1$ //$NON-NLS-2$
Is there a possiblity in EMF?
Re: Customize EMF Enums [message #1059865 is a reply to message #1059785] Tue, 21 May 2013 23:10 Go to previous messageGo to next message
Ed Merks is currently offline Ed Merks
That's not possible other than by hand modifying the generated code.
On 21/05/2013 5:19 PM, Sir Wayne wrote:
> Hello,
> values.
> Generated Code
> //$NON-NLS-2$
> Thanks
Re: Customize EMF Enums [message #1059967 is a reply to message #1059865] Wed, 22 May 2013 07:49 Go to previous messageGo to next message
Thank you for your quick reply.
Should i create a improvement ticket?
Re: Customize EMF Enums [message #1059974 is a reply to message #1059967] Wed, 22 May 2013 08:07 Go to previous message
No, the Ecore model doesn't support that; it needs the actual value to
support dynamic models and to provide those values reflectively.
Previous Topic:[Edapt] Factory problems ...
Next Topic:[CDO] Clearing a CDOResource content which has a Proxy object
Current Time: Tue May 28 11:36:53 EDT 2013
Powered by FUDForum. Page generated in 0.04841 seconds
