Home » Modeling » TMF (Xtext) » IAssignabilityComputer (How to replace it ?)
IAssignabilityComputer [message #1059733] Tue, 21 May 2013 08:52 Go to next message
Kevin SERIN is currently offline Kevin SERIN
I have a code where there are these lines:
import org.eclipse.xtext.common.types.util.IAssignabilityComputer;
public class MyValidator extends AbstractMyValidator {
@Inject
IAssignabilityComputer typeComp;
The 'typeComp' attribute is to use the mthod 'isAssignableFrom'.
I suppose that now we should use isAssignable from the interface Type.
The problem is I use a JvmParameterizedTypeReference which is not a Type.
So is there an easy way to replace the IAssignabilityComputer ?
Re: IAssignabilityComputer [message #1059908 is a reply to message #1059733] Wed, 22 May 2013 03:17 Go to previous messageGo to next message
Do you think that this is code:
@Inject
TypeReferences typeRef;
JvmParameterizedTypeReference typeReference = ... ;
JvmParameterizedTypeReference typeReference2 = ... ;
if(typeRef.isInstanceOf(typeReference, Class.forName(typeReference2.getType().getIdentifier()))) { [...] }
do the smae thing as:
@Inject
if(typeComp.isAssignableFrom(typeReference, typeReference2)) { [...] }
Re: IAssignabilityComputer [message #1059911 is a reply to message #1059908] Wed, 22 May 2013 03:23 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian Dietrich
http://www.eclipse.org/forums/index.php/m/1041571/?srch=TypeConformanceComputer#msg_1041571
Re: IAssignabilityComputer [message #1059922 is a reply to message #1059911] Wed, 22 May 2013 04:01 Go to previous message
thanks
Previous Topic:add a field Automatically
Next Topic:reload all elements from the XMFResource
Current Time: Tue May 28 17:18:21 EDT 2013
Powered by FUDForum. Page generated in 0.01477 seconds
